Chevy 10 bolt rear info
Discussion in 'The Hokey Ass Message Board' started by Bears38, Nov 21, 2011.
  1. Bears38
    Bears38
    My '49 is running a '78 chevy 10 bolt , either a nova or Camero , I need a axle shaft asap . What years/models will interchange ? I can't find anything on this online , and I'm bummin rides till I get it back together .
  2. Captain Chaos
    Captain Chaos
    from Missery
    if its camaro most 71-81 , NOva had some subtle differances through the years . Need to pull axle and count splines and measure length of axle or housing , I think nova is a little bit narrower than the camaro/firebirds in those yrs
  3. Renegade Rodder
    Renegade Rodder
  4. knotheads
    knotheads
    do you need an axle due to a bad axle bearing? check on a special bearing called an axle saver bearing.i have bought them at auto zone, it a bunch cheaper than a new axle.
  5. 38Chevy454
    38Chevy454
    Was just going to suggest this also. The design of the GM rearends the axle is the inner race for the wheel bearing. It causes wear and messes up the axle if your axle bearing ****s out. The saver bearing enables the bearing to ride on a new portion of the axle for the inner race.
  6. Moneymaker
    Moneymaker
    If you call us tomorrow with some dimensions we may be able to supply you with a new aftermarket one by Thursday.
  7. Bears38
    Bears38
    The bearing surface is too chewed up for the axle saver bearing , still trying to find numbers or any info on the housing to give me a clue as to what its originally out of . Just can't tell if its a nova or camero - or if it even matters .
  8. Bears38
    Bears38
    Thanks everyone for the replies , Moneymaker - I was going to give you a call this afternoon but this morning a coworker suggested I try the local 4x4 shop and He had a new replacement axle and bearings in stock so I'm set now . Thanks anyway !
