Projects Air ride switch problem
Discussion in 'The Hokey Ass Message Board' started by kidn1980, Nov 25, 2011.
  1. kidn1980
    kidn1980
    I have my accuair all hooked up to my switches now here is where I am confused and I am sure it is a easy simple fix or just having a bad day.:confused:I have 3 switches one for the front and one to control the back and my third to control all 4corners (slam). But when I raise my front or back it is controlling all corners. It's on a 3 prong switch
    ---=up
    ---=power
    ---=down
    On all 3 switches I have the power spliced into one source.
    Sorry for the ****py drawing. Help would be nice thank you in advance.
  2. mrconcdid
    mrconcdid
    from Florida
    Sounds like you switchs are back feeding disconect the 3rd swith controlling all four corners and see if the 2 swithes for front and back work corecttly. If so you need a 6 pole switch for all up and all down.
    Let me know if that fixes it.
    MrC
  3. kidn1980
    kidn1980
    ok i will check that tonight when i get home thank you.
