t-5 question
Discussion in 'The Hokey Ass Message Board' started by Flat-Foot, Nov 26, 2011.
  1. Flat-Foot
    Flat-Foot
    from Locust NC
    I got my hands on this transmission yesterday and I am thinking about giving it to my dad for his 32. What number do I go by when researching this trans? I was told it is out of an 89 s-10 but one of the numbers came back to a mustang. Any help is greatly appreciated.
    Also roughly what is this trans worth. I paid next to nothing, just curious what you guys think.
  2. falconsprint63
    falconsprint63
    from Mayberry
  3. 3quarter32
    3quarter32
  4. hightower611
    hightower611
    There is a paper tag that I can just see on the top cover right behind the bell housing. The tag has the numbers 1352-**X as well as a UPC type of code. The 3 identifying numbers behind 1352- will identify what it is out of. I like this website to do your simple id. http://www.5speeds.com/t5/index.html
  5. George G
    George G
    T5's sell for $100 at pick a part.
  6. box50
    box50
    Hey man, I think mine is a 89 model cant remember I paid $100 for the ****** and the drive shaft.Later on dudebox50:D
  7. Dirty Dug
    Dirty Dug
    No, it's an S-10 T-5. The only number that identifies what it is exactly, gear wise, is the metal tag number. All the rest are individual part numbers.
  8. Flat Ernie
    Flat Ernie
    Tech Editor
    The numbers you're pointing out are casting numbers - they're nearly useless. You need the metal tag (steel on the early S10, so likely rusted) that should be on one of the lower tailhousing bolts - normally on the driver's side. But you do have a UPC tag on the top cover - that will be the identifying number as well.
    Realize that these ******s are 25+ years old now and likely rebuilt at least once, so what's inside gear wise is anyone's guess.
  9. judd55
    judd55
    from B.C.
    Just by lookin, I can say with some certainty that, that is an S-10 Tailshaft and Shifter at the very least.................. :D
  10. ironhill
    ironhill
    from Simms, MT
    Definately an S-10 tailshaft and shifter, mustang and camaros had the shifter at the rear of the tailshaft. The S-10 tailshaft swap is a favorite amoung the tri five guys so the shifter is up further to use a bench seat.
  11. tmwracing
    tmwracing
    from Ohio
    Bellhousing is made for the 2.8 V6 Chevy. So I'd say S10
  12. Flat-Foot
    Flat-Foot
    from Locust NC
    Thanks for all the responses. I looked up the number on the sticker and its from a 85/86 s10 v6. is this even worth considering? It would be behind a mild 350
  13. ironhill
    ironhill
    from Simms, MT
    It all depends on how you want to drive it, for the most part the V-6 ones are geared lower in the first few gears, have less splines on the input shaft makes for a small clutch. You can go to your parts store and get a clutch with the same splines that is just about as big as your v-6 clutch would be. Other than that they are pretty much the same as the camaro v-8 trannies. Unless you are will to pay the $$ for a WC (World Cl***) one, they are suppose to be much stronger. They came in the more performance cars like the trans am ws-6 and z-28's. I did take first gear out of my in my camaro with a 305 but I was abusing it pretty hard. Put one in my dad's 56 bel air he loves it. I'm going to put one in my 57 bel air sometime soon. Its not going to be like a super t-10 4 speed but if you don't abuse it and know its there, just depends on what you want to do with it
  14. squirrel
    you can look at where it bolts to the bellhousing and tell right away that it's a chevy transmission, not a ford. The bellhousing is for the "little" V6 or 4 cylinder, you can tell by looking at it.
    Like all T5 transmissions, it has too many gears.
