Hey guys, I'm running a 4" drop axle on my 30 coupe spring over axle with split wishbones, my question is which ford steering arms work the best for this application. The 3 3/4 drop ones or the 1 3/4 one?? Thanks for the help
I used the longest dropped ones and still had to make more drop with spacers..........mIne is under frame though ,Check clearances,,,,,,,,,,,,,
Thanks for the help!! I've been doing some research and with my setup looks like the more the drop the better when using the factory wishbones. Now if using four link or hairpin style looks like the shorter ones will go right inbetween. Seems like every setup is just a bit different as well
I've got the 3 3/4" drop arms on mine, it's still a snug fit! Using tie rod ends mounted on the bottom of the arm instead of rod ends will get you a little more clearance as well. Here's the best pic I've got on hand...
