Features Restoring 1950s Ford F1 Pickup
Discussion in 'The Hokey Ass Message Board' started by OldKustoms, Sep 30, 2011.
  1. charleyw
    charleyw
    Nice work. It makes me appreciate my project more (I thought it was rusty!)
    One thing though, from recent personal experience, you may need more door hinge adjustment than the welded nuts will allow. I know that the tapped triangular nut plate is a pain but it does give a little more wiggle room. Just my humble opinion.............
  2. OldKustoms
    OldKustoms
    Thanks for this advise, but I will make larger hole in the door hinges that I´ve got the wiggle room for adjustment.
  3. henrys_way
    henrys_way
    from Maine
    Wow. Great work so far. This is cool to see, its the same work im doing on my 51 right now. Just a couple questions...
    Where did you order your bed from?
    What size & style Wheels did you go with from "wheel vintiques"
  4. OldKustoms
    OldKustoms
    @henrys way: Ordered the bed and the wheels at LMC.
    Did some metalwork on the innerstructure of the b pillar this weekend
  5. 1950Effie
    1950Effie
    from no where
    She is really giving you a run for your money. Great job! Keep the updates rolling....
  6. OldKustoms
    OldKustoms
    On saturday I found a little bit of time to pull the motor and transmission.
  7. OldKustoms
    OldKustoms
  8. nice job, good photos
    when you do a cab corner, it is literally the whole corner this is going to be iteresting to see when it done, that takes a lot of patience and metal fiting and finishing
  9. rdemilt
    rdemilt
    from so florida
    Nice Job. keep us updated on the progress.
  10. lothiandon1940
    lothiandon1940
    I'm exhausted just looking at all the work. Great job and great photo do***entation.
  11. boutlaw
    boutlaw
    Wow Marcel, you guys are doing a great job. I am very interested in how you plan to repair the inner skin and floor on the rear cab corners. You have accomplished a lot of work so far. Some of the repairs are ones that I will also have to accomplish so its good to see the process. Definitely subscribed to this thread. Keep posting those pics and good luck with the truck.
  12. charleyw
    charleyw
    Thanks for the update, I was wondering how you were coming along.
  13. OldKustoms
    OldKustoms
    I had to restore the 55 Buick Special first, so I made a break on the F1.
    But now I will start with the rear cab corner on saturday.
    After this will be done, the p***enger side needs a lot more of work than the driver side.
  14. OldKustoms
    OldKustoms
    Started with the motor on saturday.
    Will get it to the machine shop to hot-tank it and then check the block for cracks.
  15. OldKustoms
    OldKustoms
  16. OldKustoms
    OldKustoms
    Mounted the carbs on the Offy intake and installed the carb linkage.
  17. boutlaw
    boutlaw
    Any updates on the F1 cab corners?
  18. OldKustoms
    OldKustoms
    Not yet. Maybe in 1 or 2 weeks.
    Have to finish a 1950 Buick Roadmaster first.
  19. rustyF1
    rustyF1
    from Germany
    Super Arbeit, weiter so!
  20. OldKustoms
    OldKustoms
    Did some cleaning on the flathead, like you can see on the pictures.
  21. OldKustoms
    OldKustoms
    The 1950 Buick Roadmaster is finished and absolved a drive as a wedding car last weekend.
    Now I´ve got time for the F1.
    I putted the Offenhauser heads and intake on the block to see how it will looks, when it´s finished.
    But I´m undecided about the color for the block. Should I paint it gloss black or gloss red?
    This weekend I will continue welding on the cab.
    Stay tuned....
    Enough words now some pics...
  22. OahuEli
    OahuEli
    from Hawaii
  23. Mr. Tomato Head
    Mr. Tomato Head
    Ach du lieber! Das ist wunderbar !
  24. OldKustoms
    OldKustoms
    To paint the block red was my first thought. So I think I'm going to paint it in gloss red.
    In one or two weeks I will send it to the machine shop.
    Tomorrow I want to finish the welding on the driver side.
    I will keep you updated with pictures about that.
  25. ChefMike
    ChefMike
    Good for you Man !! taking this truck and making it whole again ! Great Job Keep up the work
  26. OldKustoms
    OldKustoms
    Thanks. I have a lot of body work on the truck.
    The biggest problem is the weather because I only can do the metalwork when there is no rain because I have to do it outside on the parking lot. So it tooks a bit longer then it woulds normally take.
  27. chudm71
    chudm71
    from Perryton
  28. OldKustoms
    OldKustoms
    Didn´t finish the driver side this weekend, because I removed the reinforcement between the B pillars.
    And there was also a lot of bondo on the cowl area, like you can the on the pictures.
    The holes you can see wasn´t welded! Only filled with bondo.
  29. OldKustoms
    OldKustoms
    Did some metalwork on the rear cab corner on the driverside.
    Only some few welds to go and it will be finished soon, so I can do the same work on the p***enger side.
  30. OldKustoms
    OldKustoms
