Hudson fluid drive help
Discussion in 'The Hokey Ass Message Board' started by oldskooljc, Nov 27, 2011.
  1. oldskooljc
    oldskooljc
    from Fresno CA.
    I have a 1951 Hudson Wasp with flud drive just got it running motor runs well. But I have a hard time getting trans in gear it seems to shift ok into 2 & 3. But when it comes to a stop it wants to drag again. Clutch seems to be adjusted ok. Anyone ever have this problem and know of a fix. thanks jim
  2. Canus
    Canus
    If, when you say "fluid drive", you mean a fluid filled clutch then you probably need to change the fluid in the clutch. These clutches have a tendency to "stick" especially if the vehicle has been sitting for a while. Check out the Hudson Es*** Terraplane (HET) club (Google HET) for sources for the correct fluid.
  3. Ramblur
    Ramblur
  4. Hudsonite clutch oil has been available for probably 30 years now in the original formula and don't even THINK of using any subs***ute that anyone mentions. Yes, if your clutch is sticking it should be rinsed out so check with some authority on those cars for the best cleaning solution before you put in new genuine Hudsonite. Some of those original wet cork clutches went 100, 200, 300,000 miles without replacement. Had a friend who drag raced a Hornet powered '50 Pacemaker coupe and never blew a cork clutch. All Hudson clutches were cork faced from about 1912 to 1954 except the little Hudson Jet compact of '53-54. Some extreme HD fork lift trucks have cork clutches today!
  5. damagedduck
    damagedduck
    from Greeley Co
    DAMN STRAIGHT!some really good Hudson guys over there & here,it's alittle slow going over there but guy's like--Uncle Josh,Lee,hudsontech,+ many more will help ya out with all kinds of info..so are members here too!:)
  6. oldskooljc
    oldskooljc
    from Fresno CA.
    YES You guys are way cool! THANKS AGAIN Jim
