Customs Opinions on a 35-37 pickup chop
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 24, 2011.
  1. 2-3 inches, just a little off the top
    63.1%
  2. 4 inches- seems to be the hobby standard
    18.4%
  3. 5 or more, make your neck hurt
    18.4%
  1. Roothawg
    Roothawg
    I agree.
    Burny, looks good. How big are those rear tires?
  2. This is chopped 4" in back and about 4.5 in front it had to get 1 5/16 longer.
  3. mow too much
    mow too much
    Not sure how much, but it looks good................but I would like it the same unchopped.
  4. For the chop I think something real subtle is a nice change of pace. Of course I am an idiot.
    As for the whels thing I am more interested in what type of pomade is best, wheels don't mean a thing unless you have the perfect pomp.
    Burny
    You truck is just about perfect in my eyes. When I was a lot younger there was a hemi powered truck in San Mateo built along the same lines as yours. Very fine looking truck.
  5. sammamishsam
    sammamishsam
    Zero, if you are running fenders IMO if you want to maintain the proportions and head room. You'll play hell trying to get that 6'+ frame of yours into something lower and have a crick in your neck after 15 minutes of driving.
  6. Roothawg
    Roothawg
    Sam, I drive my dad's quite a bit and it's chopped 4", but I tend to lean towards the lesser.
    Bruce, that is along the lines I am talking about. That looks dang near perfect.
  7. Jeem
    Jeem
    Alliance Vendor
    I'm biased but....
    Also, I've shortened the WB by 2 inches. I'm going to shorten the bed a similar amount but close up some of the cab to bed distance....so maybe only a vertical inch from the front half of the bed. Also, the rear of the bed ('37) will be shortened 4 inches to match the length of a '35 or '36 bed (Root pointed that out to me a couple of years back).
  8. theHIGHLANDER
    theHIGHLANDER
    2-3" is just about as good as it gets. Too much chop looks cartoonish and out of proportion. I don't care if the driver's 6'6 or 5'6, getting the balance of hgt and length is where it's at. How much was taken out of Winfield's truck? I'm doing 3" on an AD to avoid quartering the roof. I have it all laid out but haven't put the saw to it yet. It probably won't see sparks for a year or more. FWIW, I'd match the overall rake of the windshield to the rake of the grill, or vice verse...
  9. I think that the more you do the more you need to do. If you chop too much then you need to section to get away from the body looking too think, if you section you should probably also shorten it up a little so it doesn't get the waffle look. Having too heavy a hand is a very vicious creature.
  10. 1 KooL "MoFo"
    1 KooL "MoFo"
    I have a few but dont know how to post them :confused: ? you can see them on member under my ID
  11. Roothawg
    Roothawg
    Any more info on this truck? I like the way everything is well done and super sanitary.
  12. Unfortunately no. Sorry. It stopped me in my tracks and the owner happened to be sitting there. I asked him how much it was chopped, told him it was perfect, and went on my way.
  13. Dirk35
    Dirk35
    I vote none, but that wasnt an option, so I didnt click on a ****on above.
  14. cvstl
    cvstl
    from StL MO
    I think that grey truck is the one with the '40 dash and column in matching body color. Looks super nice. I'd love to see it in person.
  15. OoltewahSpeedShop
    OoltewahSpeedShop
    I'd chop it 1" for three reasons...
    1. To piss off any limp **** purist that might ever want to restore it.
    2. To make the Hot Rodders wonder "What the hell is different about it"
    3. Because they were so close to perfect to begin with.
    Since that also wasn't an option, I figured I'd explain. :rolleyes:
  16. falcongeorge
    falcongeorge
    from BC
    yup, X2
  17. falcongeorge
    falcongeorge
    from BC
    That DOES look damn good. Is it too late for me to change my mind?
  18. Burny
    Burny
    7.00-16 Firestones Diameter is about 31" (if I remember correctly)
  19. houseofhotrods
    houseofhotrods
    Mine is 5 inches. It's already done, so not a big choice there for me. It doesn't make my neck hurt - as the seat base is sectioned - I am 6ft 3. Someday it'll be shiny, but drivin' it for now. :)
  20. afaulk
    afaulk
    If yer really stressin' over this, make it a roadster with a removable hardtop. Hmmm which do i like best blondes, brunettes, or redheads? They all look good to me
  21. ardyboy
    ardyboy
    Mine is 3 inches. My 6'2" son has plenty of room in it
  22. 1 KooL "MoFo"
    1 KooL "MoFo"
    Here is my 37 ford P.U. still in the works [​IMG]
    3" in the front and 4" in the rear font pillars leaned back
  23. 1 KooL "MoFo"
    1 KooL "MoFo"
    Rear view of cab [​IMG]
    not the best pic
  24. kustomd
    kustomd
    Mine is chopped 5" but its a F'n ___ rod that I've been trying to turn into something better. I'm 6' 3" or so and I fit in mine fine but my cabs been stretched and it has bucket seats bolted to the floor with no seat riser except for the stock mustang sliders that the seats came out of. If these trucks weren't so hard to find I'd just take the cab loose, shorten it back up to a reg cab proportions and put the fenders back on. but since I don't have any of the stuff to do that with I'm going to make due and just build a better looking "Rudy truck" as everyone calls it. I think 3" would probably be best for a fendered truck if you like to change it up transmittion wise everyonce in a while I.E... 4speed manual to automatic or auto to stick. That way you have plenty of room.
    I just wish I could find a 35-36 truck windshield frame for mine and the upper dash rail.
  25. Roothawg
    Roothawg
  26. Don Martin
    Don Martin
    from West Tenn
    If it's got fenders less chop, no fenders chop it till it fills good.
