64 f100 floor pan
Discussion in 'The Hokey Ass Message Board' started by Tigger!, Dec 1, 2011.
  1. Tigger!
    Tigger!
    Can someone tell me where I can buy a good 64 f100 drivers side floor pan?
  2. shocker998md
    shocker998md
    dude make one urself. It gets covered by carpet anyway. From what ive seen all the floor pans still need some work to fit right. In my build thread I have pics of when I patched mine because they were not that bad and I did it all with basic tools. I even got the steel free from a metal supply place that has a scrap bin and they said I could have whatever I found.
    It cost me one night of work and a few beers.
  3. ryno
    ryno
    Dennis carpenter, or national parts depot?
  4. Tigger!
    Tigger!
    Shocker998Mr,
    Unfortuately I'm not that talented. I wish I could. Lol
    Ryno,
    I will try them.
    Thanks
  5. hellbentbilly
    hellbentbilly
    from delanco nj
    flashback f100s. in north carolina. nice stuff
  6. Tigger!
    Tigger!
    Ok hellbentbilly thanks!
    Also, if there is somebody that has one and doesn't need or want it let me know.
    Thanks !
  7. ChuckleHead_Al
    ChuckleHead_Al
    I think LMC sells everything you need.
  8. Tigger!
    Tigger!
    Yes I believe they do but I have read bad reviews about them.
    Thanks
  9. shocker998md
    shocker998md
    Does your hole floor need replaced? Its really not that bad and I learned alot from me doing them on what I will change the next time I do a set.
    If you look up tin man on here he made a set that are very nice out of hand tools. You can learn alot from it.
    Its up to you though, if you buy some id stay away from lmc. But im betting that even higher quality ones you will still have some fitment issues.
  10. shocker998md
    shocker998md
  11. Tigger!
    Tigger!
    The rust isn't that bad. it's around the bolt on the drivers side floor and it's not rusted through yet but will be.
  12. 302aod
    302aod
    from Pelham,Tn.
    Tigger I'm not that talented either, but after cutting out the rusty 64 floor and trying to put in an 87, I found that the 87 floor made the seat too high and was very different in the angle to the firewall. I bought a bead roller and am making a new floor from a piece of sheet metal.
  13. Tigger!
    Tigger!
    Thanks for the advice 302aod.
  14. shocker998md
    shocker998md
  15. Tigger!
    Tigger!
    Shocker998md,
    Thanks! I just ordered the one I need from this guy.
    Thanks once again.
