Info/Pics 1948 to 1952 Ford F1 Trucks
Discussion in 'The Hokey Ass Message Board' started by 50chevy, Jul 6, 2006.
  1. 45Shooter
    45Shooter
  2. limp
    limp
    that is a good looking truck you got there, congrats
  3. wildearp
    wildearp
    from tucson, az
  4. E.B.
    E.B.
    from Hudson, WI
    I just came across this photo. Great job! I am building a 1952 F1. What motor and trans did you use? It looks like a perfect fit.
    E.B.
  5. Mr. Clean
    Mr. Clean
    Here's my 48 in progress. So far it has a 2" chop, sbf, tremec trans, and air suspension.
  6. flashback
    flashback
    Does anyone know if 1948-1950 trucks fender wells were painted the body color or painted black from the factory?
    John
  7. bobj49f2
    bobj49f2
    As far as I know they were black. The inner fender panels would have been one of those generic pieces stacked in a pile next to the ***embly line and just bolted in as the trucks came down the line. It would have been a nightmare to make sure the panels were painted to match each truck coming down the line.
  8. hooligan1952
    hooligan1952
    from Maryland
    2nd truck is mine. I bought it off eBay a few years ago.
  9. Invicta
    Invicta
    here is my 52
    exterminator and waxhead like this.
  10. 51PanelMan
    51PanelMan
    Nice truck INVICTA!!! I like the color combo. I have a spare stainless steel windshield trim if you're interested.
  11. Sanford&Son
    Sanford&Son
    from Visalia,Ca
    The Black Chopped and Channeled was built my friend Tim Gowett in Woodlake Calif "Gowett Speed & Custom".
    exterminator likes this.
  12. Invicta
    Invicta
    Thanks 51PanelMan I have one hanging up in the garage, I just haven't tried to put it on yet.
  13. 50chevy
    50chevy
    Thanks for sharing everyone.
  14. 49F1Jeff
    49F1Jeff
    from Oregon
    Our '49 we picked up a couple months ago. It is now being readied for the road (brakes, engine swap, general clean up/frame painting) so we can hit some cruises next summer.
  15. 1952henry
    1952henry
    As is the F3 (heavy duty 3/4 ton) The F4 was Ford's advertised 1 ton.
  16. fullerton
    fullerton
    Picked up my 52 on Sunday, too busy to break into it yet with the holidays, but after the new year, it's on.
  17. train
    train
    Please help I have 48f1 p/u stock rear 6cyl 4spd need to change out 427 gears in rear,its a ****er/Dana 41. 18423.I want to put 354 or lower gears in,any help would be great,thanks train
  18. bobj49f2
    bobj49f2
    The easiest thing to do is swap in a pre-'73 F-100 9" rear axle. It's basically a bolt in. You'll have to either weld new shock mounts or find a set of spring perches from a '48-52 F-2. You might also need a longer transmission yolk.
    http://fatfenderedtrucks.com/rearaxle.html
  19. Great thread, Here is my build in progress 50 with a 51 front clip.
  20. 51PanelMan
    51PanelMan
    Nice. Looks like you have F2-F6 front fenders.
  21. B1rdwchr
    B1rdwchr
    I've got a '50 F2 and am searching for some good rear fenders. Can you tell me if the rear fenders on F2s are the same from 48-52?
  22. bobj49f2
    bobj49f2
    F-2/F-3 rear fenders are the same from '48-52 for the 8' Express boxes. Unlike the F-1, Ford didn't dramatically change the boxes in the mid 1950 model year. The Express had the raised side panels from the early '40s to '52, the F-1 boxes had flat sides starting in the mid '50 model year. Rear fenders also changed in mid '50 for the F-1 with the elimination of the notch to accommodate the raise panel. The only difference I've seen in the Express box is the shape of the inside wheel bump, and this didn't affect the fenders. My original box on my '49 F-2 had round bumps, the box I replaced it with had oval shaped bumps. I've had at least 5 '48-52 F-2/F-3 trucks and it doesn't seem to matter what year the truck is because other than the box I am using I haven't had a truck with the oval bumps. Ford didn't seem to follow much of a construction procedure, they seemed to used whatever was closest to the ***embly plant and whatever was cheapest to get. The was being used as a trailer when I got it so I don't have any idea what year it was used on.
    If you're not aware there are two differences between F-1 fenders and those used on the Express boxes. Smaller wheel openings, like the front fenders, and the Express fenders are narrower to accommodate the wider box.
  23. chappychapperton
    chappychapperton
    Here is a picture of my 52. Front fenders are primered now, gl*** is in. Been working on this with my dad for three years now....... looking forward to putting some black paint on it... or blue..... :confused:
    73 camero clip
    lowered front and rear
    fuel tank in rails
    302 with a few extras (intake, carb, headers, decked)
    C6
    10 bolt chevy rear
    49 hood
    chrome grill
  24. eghatch15
    eghatch15
    from NC
    I like the truck. Id like to see more pics
  25. 52f6guy
    52f6guy
    from Maine
    Hi I am restoring a 52 F6 and in need of front fenders, I noticed you have a 51 and 52 F2 and F3. The fenders to my knowledge are the same from F2 to F6 for51 and 52. Would you be able to help out with any fenders to buy or put me in touch with someone who has some. Thanks.
  26. RustyArmadillo
    RustyArmadillo
    from Dallas
  27. RustyArmadillo
    RustyArmadillo
    from Dallas
    Here is mine, just picked her up a week ago.
  28. chappychapperton
    chappychapperton
    Just had the truck painted! Used ppg bc/cc. Turned out really nice. Now for putting it all together.
    Going to run smoothies with a small center cap but cant decide on black with cap and beauty ring or red? Whats your thoughts?
    Thanks
  29. charleyw
    charleyw
    Looks good! Correct color too.
  30. RPW
    RPW
    This it what I drive on daily basis during the summer, a 1948 F-1 with a smallblock and a th350. I found it advertised here at HAMB, brought it from Tucson Arizona and got it registered in Sweden in July 2012. It is by no means a show car, but I'm continuously improving it to be a good and reliable driver.
