Dec Banger meet.... Christmas on all four
Discussion in 'The Hokey Ass Message Board' started by Bluto, Dec 1, 2011.
  1. Take the vaporiser plate off and make up a flange for a header pipe would be cool.
  2. Just picked up a Mallory distributor from a Model A engine used for a Gleaner combine (?)- any ideas on where to find parts for a rebuild/switch it over to dual point?
    [​IMG][​IMG]
  3. Bigcheese327
    Bigcheese327
    You gonna run that on your Chevy? Or are you switching over to the dark side, Mac?
    -Dave
  4. I'm hoping to modify it... and stay in the light, Dave :)
  5. Stovebolt
    Stovebolt
    Guys, wish me luck - on Aussie ebay at present there is a complete early A ?AR ch***is that I'm bidding on. it ran last year. i will drop my coupe body on it and off I go.
    Juice brakes, dropped axle and T 5 later.
  6. Brendan1959
    Brendan1959
    Looks like a great start and a good price, hope you get it
    Brendan
  7. youngster
    youngster
    from Minnesota
    Take a look at the cast drums and full floaters. I just rode and drove a '29 with them in it. They are amazing!
    Ron
  8. ebtm3
    ebtm3
    I run ' 32 front brakes and Ted's floaters on my '30 two door. Works so well that I haven't yet bothered to install the rear floaters.
    No reason at all to go hydraulic. You have to adjust mechanicals more often, but on a car that is not driven high annual mileage- it isn't that often Never had a car with mechanicals that had leaking problems--even with once a year use
    Granted, when I drove an A as a regular driver 50 years ago, I converted them to hydraulics. Back then, working with junkyard parts, and hard linings meant for juice brakes, stopping was a major problem. Now that we understand what is important to get mechanicals to work properly- the problem is solved.
    Herb
  9. ebtm3
    ebtm3
    I have a couple early Malory distributors that I won't ever use.
    PM me for info.
    Herb
  10. 'zat me you're talking to Herb??? :D
    PM sent
  11. kenagain
    kenagain
    from so cal
    You don't think single points on a mallory aren't enough of a problem??
  12. Bluto
    Bluto
    NAPA Has the cap in their user's guide
    My copy is in Poland sorry
  13. BCCHOPIT
    BCCHOPIT
    Ok guys I have a question for you.
    Where do I hook up the power wire to my B dist.
    I looked in my books and it only talks about the A
    As always thanks
  14. Bluto, do you remember what number they had the cap under?
  15. BCCHOPIT
    BCCHOPIT
    I am thinking the power wire is here
  16. Bluto
    Bluto
    "Bluto, do you remember what number they had the cap under?"
    No I don't keep part numbers in my head for things I will NEVER use :D
    Go to NAPA and get a users guide. It's even got photos.
    NAPA has several guides like this ....... they are free and everyone building stuff should have a set of these guides.
    There are folks on Egay selling NAPA stuff out of these guides as NOS!!
  17. Same screw as the condenser in the photo.
  18. BCCHOPIT
    BCCHOPIT
    Thanks Bill
  19. Stovebolt
    Stovebolt
    I just thought I'd inform you guys that I won the Auction on fleebay so I will be busy in 2012 getting my coupe on the road as a "stocker", then as finances allow, it will receive some hopping up. Juice brakes, dropped axle and a Jeep T5.
    I needed something to motivate me to work on the coupe
  20. j-stovebolt
    j-stovebolt
    from Minnesota
    I've been checking in on the banger meets for a while but this is my first post. Working on a model b with 2, 81 carbs. To any of you guys with 81's on your banger my question is, what size jets are you running?
  21. Timberbeast
    Timberbeast
    I am curious as to how you fit rhe "T" radiator to the "A" front crossmember. I'm planing to start a t speedster on an "A" frame in the spring. Trying to get some of the parts lined up before it gets warm.
    Thanks
    Jerry
  22. Hi Jerry - the radiator is a special build. Model A bottom tank, T top tank with a scallop out to miss the fan and an offset top hose. The bottom plate is wider than the A one to match the T grill shell. I re-drilled the front cross member to suit. I'll try and sort out some pictures maybe tomorrow - I'm having a go at making a 4-piece hood.
  23. -Brent-
    -Brent-
    Mark... nice ch***is!
    Finally!!!!! :D
  24. RichFox
    RichFox
    At last a Dodge Bros. update. After only 11 months and better than $1100 I have timing gears.
  25. BCCHOPIT
    BCCHOPIT
    I like the holes. I put holes in my alum. gear. But its a ford and I only paid $50
    Did they come with Straight cut gears?
    How many sets did you get for your $1100
  26. Gary in MN
    Gary in MN
    Hi Rich: Here is a Morton & Brett flyer for Dodge.
    Gary in MN
  27. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Congrats Mark, Stay focussed. This should be a fun build for you.
  28. RichFox
    RichFox
    Nice Morton & Brett ad. Thanks. The Dodge Bros, gears were Hypoid. But no longer fit after line boring the Dodge block. So that meant three new gears for the new centers. I will agree that $1300 is way high compared to what I paid for my Plymouth cam gear. And 11 months is so long to wait if I was the gear cutter I wouldn't have the balls to charge at all. But I did hear some interesting excuses. I don't want to bad mouth Dan publicly. So anybody who wants to know the name of someone I would never consider for any thing I needed, PM me.
  29. BCCHOPIT
    BCCHOPIT
    At shop rate today. That is not a bad price for one off gears. My bosses would have been a lot more. A lot faster but a lot more money.
    Did you move the crank to make room for more stroke or less? Is your cam centerline in the same spot?
  30. brokenspoke
    brokenspoke
    I asked my local NAPA store about the guides....I dunno was the answer...any part number or suggestion?
