sbc question
Discussion in 'The Hokey Ass Message Board' started by glendale, Dec 9, 2011.
  1. glendale
    glendale
    Hey guy and gals i have a quick question. my car has a sbc in it. i just pulled it do to a horrible oil leak. i have been thinking front main seal all along. i know it's coming from the front of the motor. well when i got it out and on the stand i noticed oil dripping from a bolt hole. could this be my issue? when i put the motor in the car it was a hurried thing and i had never actually had a sbc on a stand or anything. so i am thinking this is my issue. either way i am going to regasket the whole motor and change a bunch of stuff i would just like to solve it before it leaks all over the place again. here is a pic any help would be greatly appreciated.
  2. hotroddon
    hotroddon
    Yep, very common that guys leave that open and it pukes oil
  3. squirrel
    yeah, you need a bolt to seal up that hole. The fuel pump push rod goes right past the hole, it's open to oil.
  4. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    suppose to have a bolt there, other wise it leaks from the fuel pump push rod.
  5. rd martin
    rd martin
    from indiana
    That bolt hole runs into the side of the push rod for the fuel pump, if it is left open a small amount of oil will come out of it. You need to seal it with a short bolt, with a little sealer on the threads of the bolt.dont use a long bolt, because when you tighten it , you will lock the fuel pump rod, then you will have another problem.
  6. glendale
    glendale
    Wow thanks for the fast response! Gotta love the hamb!
  7. grits
    grits
    What year sbc is it, I don't have that problem with mine, mine is s 74
  8. fab32
    fab32
    When the engine came from the factory there was a short bolt in that hole with a lock washer under the head. When a fuel pump is changed your supposed to take that bolt out and remove the lock washer and replace the bolt tightening it very carefully as it contacts the fuel pump push rod. This will prevent the push rod from dropping into the cavity that the pump lever operates in when the pump is removed. Then you remove the pump, install the new one without the h***le of having to rig a way to hold the push rod up while installing the new pump. After the new pump is bolted securely you remove the bolt, reinstall the lock washer and tighten the bolt securely. Simple, huh? Those SBC guys really knew what they were doing didn't they?:cool:
    Frank
  9. gasser300
    gasser300
    from Ft Worth
    Right on Frank.
    And that 74 should be the same way!
  10. Bad Banana
    Bad Banana
    Umm... don't want to be a smart *** but he has a fuel pump block off plate on there... :D:cool:
  11. Mr48chev
    Make that a Short bolt =3/8 nc x 1/2 inch. Too long of a bolt will hit the fuel pump pushrod.
    It really makes a mess when that bolt is missing doesn't it? No need to ask why I would know that or that the short bolt that holds the alternator bracket to the intake is just the right length to work great in there.
  12. Mr48chev
    Yep we missed that but a guy still wants to use a short bolt in that spot.
  13. grits
    grits
    Ok,
    Frank, I just looked at my 2 other older sbc and you're dead on, I totaly forgot about that. I have a 1964 283 and a 1963 327 and the both have that bolt in place, the 350 in the coupe is a 1974 block and doesn't have that bolt.
  14. grits
    grits
    My next question is, What year did that change? I'm just curious :)
    Or is that just a 350 thing?
  15. gasser300
    gasser300
    from Ft Worth
    The block has the 2 bolts on each side as they were motormount points on the early ones.
  16. Reds 29
    Reds 29
    I have a '72 350 block and it has that bolt. I read in a rebuild manual about how to use it to hold the fuel pump pump rod, like fab 32 said.
    Red
  17. dave lewis
    dave lewis
    from Nampa ID
    All small blocks that have a fuel pump push rod have that hole...
    That being said, I have seen a few without the bolt in place leak like a gushing oil well!
    And have seen 2 that went thousands of miles without the bolt and never leaked a drop, until one day, out of the blue...puddles..
    It appears that a plug of sorts can build up behind the short bolt( some kind of oil residue) and seals the hole...until somebody flogs the car thru the gears...Both cases above happend imediately after a manifold/header swap..(gotta flog ER>> test drive it right ?? LOL
    Dave
  18. Jay Tyrrell
    Jay Tyrrell
  19. And then the guy that replaced a bracket while he lost a bolt. Then he put a bolt in just long enough to seize the fuel pump pushrod.
    He did better than the guy that had the fuel pump pushrod for an EARLY 4.3 V-6 that had one floating around in his toolbox and took a while to figure out it is shorter than a std SBC piece. Me.
  20. burnout2614
    burnout2614
    If the push rod is not in there LOTS of oil will p*** through. peace
  21. Mr48chev
    Somewhere along the way GM decided that they didn't need to drill and tap the holes that originally were for the motor mounts on 55,56 & 57 Chevys. Guys threw a fit when they couldn't use the later engines in an early car without having to drill and tap the blocks. Shortly there after they started drilling and tapping them again.
    Some of the engines like the one Glendale has or the one I have may have originally had a bracket that fastened on with that bolt and that is why the bolt ended up missing.
  22. Changing gaskets makes no sense if they are not leaking.
  23. glendale
    glendale
    If you already have new heads/valve covers/intake /and cam you will?
  24. marman1950
    marman1950
    This is a perfect topic... I just came back from the Mooneyes Christmas show and I opened my hood to find oil all over the crossmember.. Sure enough it looks like its coming from the hole next to the fuel pump. I have around 6k miles on the motor since the rebuild and it never leaked before!!! It's weird that it suddenly started to gush...
  25. racer67x
    racer67x
    older ones used the holes for motor mounts..mid 70's vans use those holes to mount the power steering pump bracket.
    when running no bolt hole camel humps and needing to run power steering that style pump comes in handy.
