Crankshaft Scraper HP
Discussion in 'The Hokey Ass Message Board' started by super plus, Dec 9, 2011.
  1. super plus
    super plus
    Has anyone played with crankshaft scraper locations on a dyno , lets hear what you found in the way of HP :):rolleyes::eek:
  2. I'm not sure what you could gain by putting the scraper anywhere other than as close to the throws as possible....
  3. yellow dog
    yellow dog
    from san diego
    The main concern with a scraper is how to attach and make it fit...not a lot of options
  4. falcongeorge
    falcongeorge
    from BC
    The real gain is in minimizing the oil level. Theres a lot of other things you need to look at to sucessfully do this in the kind of package you have to fit in most cars, but there are BIG gains in keeping the oil as far away from the crank as you can.
    Oh yes, another thing, a scraper is much more effective if the counterwieghts are round, rather than cam ground. There are SUBSTANTIAL gains to be had in oil control, but you really need to think about every aspect of what you are doing.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thinking along those lines[oil level] would running a "marine style" or full sump pan be beneficial??
    dave
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yes... but you have to make sure the oil will stay near the pump pickup during hard cornering, accels, and decels. This usually means baffles and trap doors, depending on the application (drag, road race, rock crawl, etc.).
  7. falcongeorge
    falcongeorge
    from BC
    IMO, which is pretty drag-centric, the BB mopar/late hemi set-up with external lines and a swinging pick-up is about as good as it gets for a wet-sump system. You can go a long ways down the minimal oil level road, but its not an "add-on", you have to take a holistic approach, starting with the clearances you run, and this puts a real premium on quality machine work. The Stock eliminator guys are the ones who have really taken this to another level, and they are stuck with a stock depth pan. The downside is there is a price to be paid in valvetrain longevity, especially if you are into a combo with a really big cam. Lots of oil to the top-end helps carry heat away from the valve springs. But there IS power in the pan.
  8. CutawayAl
    CutawayAl
    from MI
    On a genuinely streetable engine(realistic RPMs), with stock stroke, and a decent oil pan, a scraper isn't going to do anything. At the other extreme, high RPMs, long stroke, a poor oil pan, or oil level too close to the crank, can result in the crank picking up a lot of oil from the pan. One of the advantages of dry sump is avoiding that problem.
    As to oil flying off the crank, that oil slings off in every direction. The scraper only catches it at one point.
  9. Pro Shifted
    Pro Shifted
    I would also consider a kickout on the pan to give the oil a place to go after it is scraped off the crank instead of "balling up" against the throws.
  10. super plus
    super plus
    I should have made this a little clearer , Dry sump with scraper in different locations in the pan not just on the rail
  11. falcongeorge
    falcongeorge
    from BC
    LOL! Yea, you probably should have mentioned the "dry sump" part!
  12. falcongeorge
    falcongeorge
    from BC
    I would take issue with both of these statements, ESPECIALLY the second one!
  13. CutawayAl
    CutawayAl
    from MI
    What I posted is real world testing and experience, not assumption or anecdotal belief. But, if you don't believe it that's ok with me. All I can tell you is that it is good info. You would recognize the names of at least some of those who have invested the time, effort, and expense to investigate and experiment with this. They probably wouldn't appreciate my saying as much as I did.
  14. GOATROPER02
    GOATROPER02
    from OHIO
    The larger the "box" on the right side of pan as well as depth of the pan...is what is most efficent in a drysump
    Also a minimum of a 4 stage but pref a 5 stage oil pump
    Sealed valley with 1 stage scavenging valvetrain oil
    3 stages sucking on the pan
    Sealed vc's
    Vent on the tank
    This way also creates a vacuum in in the engine of a approx 12-14 in with good ring seal
    Keeps oil pulled down off cylinder walls
    Lighter ring package can be used
    This will make more power than any scraper will
    Tony
  15. badshifter
    badshifter
    Sounds like a traditional hot rod build to me! What's it going in?
  16. falcongeorge
    falcongeorge
    from BC
    Yup.
  17. falcongeorge
    falcongeorge
    from BC
    The oil does not sling off in all directions, it clings around the crank/rods in an aerated mass. And yes, I want to hear the names of the guys who came up with that crock, feel free to pm me if its too "top secret".
  18. Lucky3
    Lucky3
    I race with a very high rpm sbc (800+ hp). We find 17-20 hp with a scraper hand fabricated and biased to the right hand side. Run 8 qt Milidon Pan and use 5w-30 XRP racing synthetic oil. Street motors won't benefit much....
    Just seen your added comment about a dry sump system.....rarely used and minimum effect.
    Hope this help !
  19. GOATROPER02
    GOATROPER02
    from OHIO
    Yes sir
  20. super plus
    super plus
    I can't see why a scraper in a dry pan even more than one scraper would not be worth HP . The deeper the dry pan and 4 & 5 stages & venting is a no brainer. I just wonder if anyone on here has played with this
  21. MAD MIKE
    MAD MIKE
    from 94577
    And getting it away from the crank as fast as possible.
    One thing I think some folks don't realize, is it's not just the spinning crank that causes the oil to be flung all over, but the pumping of the pistons in a 90* V8 creates turbulence. This turbulence is what will also churn oil, that's already in the pan, up. This is where a windage tray works its magic. It helps collect the oil being slung about, and prevents the turbulent air from directly churning up and aerating the oil already in the pan.
    If there is room in the pan you are using, a windage tray in conjunction with the scraper will aid in freeing up power and prolonging engine life with good oil control in a street car.
  22. Wrong... The oil forms a "streamer" that is wrapped around the crank. Some guy named Yunick (heard of him?) got a slo-mo camera inside an engine and filmed the components under actual operating conditions. The streamer would dip down into the oil in the pan sump and replenish itself. They measured a still photo and found that streamer was over 20 ft long at 8000 RPM. That's where the original idea for a crank scraper came from. If you go to a parts house that still has one of those Lucas Oil gear models on the counter, you can see that streamer begin to form just cranking it by hand...a far cry from extreme high RPM...
    IIRC (from the book), they positioned the scraper to slice the oil streamer off as it came down past the "leading" pan rail. That kept it from picking up more oil on the way past. I believe Smokey mentioned that they got rid of so much oil that they burnt the valvetrain up on the dyno engine before they realized it was dried out.
  23. TR Waters
    TR Waters
    from Vermont
    wet sump with full teflon coated scraper
  24. Lucky3
    Lucky3
    Similar design to mine but I had no pics of it....several iterations were created and some helped and some didn't. The store bought screens didn't show any gains but the scraper does. I Also have to use a vacumn pump and run 9-11 HG of vacumn which is another 17+hp gain. :D
  25. CutawayAl
    CutawayAl
    from MI
    Depending on the particular point made, both of you are outright incorrect, or misunderstanding what you are seeing or what you read. You have plenty of company, so don't let me change your thinking.
    Smoky wasn't a dummy, but he didn't know everything, and like anyone else, he didn't always understand what he saw. He wasn't the god most think he was. Things he did and said over the years prove that, and his books document it in writing.
    Yes a crank may pick up oil from the sump, but that's not the same as high RPM windage, or the idea of a fantasy ball of oil clinging to a crank rotating at 5,000 RPM.
    George,
    Why would I PM you with more info? Your mind is already made up, and I don't feel obligated to convince you that what I posted is valid. I'm just some guy on the internet anyway, so believe as you wish.
  26. super plus
    super plus
    This is my point with crankshaft rotation clockwise ,think were the oil is going coming off the scraper mounted on the pan rail . There has to be gains moving the scraper lower in a dry pan . This is taking in account of deep pan , vaccum pump , windage tray ect
  27. GOATROPER02
    GOATROPER02
    from OHIO
    Right away ...we have all started a debated
    We have also missed an obvious part of the equation....
    We never asked what type of engine we are working on.....v8,v6,L4, chevy,ford,Toyota etc,
    While the basics apply.... We dont know if it's a high hp unlimited engine where gains found with scrapers described are debatable
    Or something small inch with many restrictions where your fighting for every last hp
    It also matters where the crank centerline is... Example. SBC vs a 426 Hemi or Y block style case
    Tony
  28. falcongeorge
    falcongeorge
    from BC
    Bingo. Give the man a cigar.
  29. falcongeorge
    falcongeorge
    from BC
    Another really good point. I talked to a BBM SS racer who added a plate to the pan rail and kicked the side of the pan out 4", told me he saw 15 hp on the dyno over a conventional Milodon full-length sump/swinging pick-up combo. Dean Nicopolis used to run a similar set-up. Thats HUGE in a well scienced out SS motor. A wiper alone wont help as much in an FE or BB mopar, as the walls are so close, and extend below the centerline of the crank, and theres nowhere for the oil to go.
  30. falcongeorge
    falcongeorge
    from BC
    In my opinion, if there is enough distance between the crank/rods and the oil level and sufficient baffling in the pan, a tray can actually work against you. If the oil level is low enough, I think you are better off with a wiper and a kick-out, no tray.
