1988 S-10 rear end question
Discussion in 'The Hokey Ass Message Board' started by Lakermatt, Dec 10, 2011.
  1. Lakermatt
    Lakermatt
    from Fresno,CA
    Hello all, has anyone ever used a rear end off a 1988 s-10 for their 47-53 chevy truck before? I am buying the T-5 transmission out of it and want to buy the rest of the drive train for a total swap out. Please let me know if this would work. Thanks!
  2. nummie
    nummie
    If I remember right, it's a little narrow and I'd be careful how much power I put through it, as it's originally got the automotive equivalent of a Briggs and Stratton powering it.
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Dont worry too much about power on it. Had a friend in high school with a NASTY small block in his s-10.
    He kept 200lbs of sand in the back, that thing would launch so hard and twist the springs till the driveshaft kissed the ground.
    The rear lasted longer than we ever thought. Second owner blew the motor, still had the same rear in it
  4. R Pope
    R Pope
    2WD S10 rear is too narrow, look for a 4WD one, they are 4" or so wider.
    As for strength, they are a small pinion shaft 10" rear. Under 300 horses and it will last a long time, as long as you don't drive like it's stolen!
  5. john mullen
    john mullen
    55 - 57 chevy rear will work great also just dont snag on it to hard .It works good for street use as a driver
  6. Jalopy Joker
    Jalopy Joker
    do search here for links to rear axle width charts. with all need to verify gear ratio. try project33.com for calculator on what ratio best for you. if using S10 only way to know ratio is by tag in glove box or pulling rear cover off and do some counting.
  7. lawman
    lawman
    !999 S-10 4X4 Blazer rear in a 1951 Chevy 1/2 frame.
  8. primed34
    primed34
    There is a code stamped on the right side axle tube that can give you the ratio. May have to go to a dealer parts dept. to find out what it is.
