how much paint?
Discussion in 'The Hokey Ass Message Board' started by purplerod, Dec 10, 2011.
  1. purplerod
    purplerod
    from florida
    We are going to paint a 31 chevy 2dr sedan the primer is black and the color will be purple .Is one gallon enough for the body and fenders?[​IMG]
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Alot depends on the type of gun being used. The newer hvlp guns don't waste nearly as much as the older guns that blew most of it into the air. But a gallon should do it IMO.
    Don
  3. Chucky
    Chucky
    Yes, 1 gallon will be plenty.
  4. ironandsteele
    ironandsteele
    We went through 3/4 of a gallon on my coupe
  5. john mullen
    john mullen
    It depends on the paint .I used someones second line paint trying to save money. (Don't want to give the brand as they all have a second line economy paint) I found out latter that this grade of paint didn't have as much pigment in it and it did not cover very well. I had to go back and buy another gallon to finish the job. I wont do that again and I recomend you buy top line paint for your project whatever your brand choice ppg, dupont, dittzler or what get the top line.....
  6. 39 All Ford
    39 All Ford
    from Benton AR
    IMO a gallon will be more than enough to paint the outside of the car, if you are painting under the fenders, inside the cabin, etc. a single gallon probably won't quite do it.
  7. R Frederick
    R Frederick
    from illinois
    A gallon will be more than enough, but don't get any less. I'd rather have a little extra than to try to match another batch.
  8. TMSTransport
    TMSTransport
    Single stage or basecoat clearcoat?
  9. purplerod
    purplerod
    from florida
    base clear. mix ratio is 3;1
  10. mj40's
    mj40's
    My 40 pickup is going to use 2 gal. by the time it's done. We still need to paint the running boards, rear fenders and bed and have used 1 1/2 gal so far. One step in yellow.
