any creative use for these aluminum water bottles?
Discussion in 'The Hokey Ass Message Board' started by Mark, Dec 10, 2011.
  1. Mark
    Mark
    from CT
    got a few of these free from work, could prolly get a few more. Aluminum can, threaded insert. All i can think of is a radiator overflow. Or maybe i should just blast it, polish it , get it pinstriped and have the coolest water bottle around.
  2. Need something familiar next to them so we can get the size of them.
    Doc.
  3. Deuces
    Deuces
    What are they???....
    2-3 gallon jugs???
  4. Let's say you're on a long drive and you really need to pee, but you just don't want to stop.............Of course you would need to put a warning on them
    Do not text while peeing while driving.
  5. Normal Norman
    Normal Norman
    from Goshen IN.
    They would need a larger opening if used for p***** in. N.N.
  6. Pinstriper40
    Pinstriper40
    Puke tank for a radiator. Polish 'em!
  7. racer67x
    racer67x
    thread a fitting in the bottom,a piece of hose and use them for rearend fill cans...polished and mounted up on the chassis with a nifty bracket they could be slick.
    we ran something like that on quick changes and it helps keep them cool.
  8. Aren't they stainless steel?
  9. Mark
    Mark
    from CT
    sorry about the measurements. about 2 5/8" diameter, 7" tall. holds 20oz of liquid. I think they are aluminum , judging by how light they are, but could be wrong. the threaded insert is prolly just anodized aluminum.
  10. R Frederick
    R Frederick
    from illinois
    :DYou could use them to hold drinking water in case you get thirsty.
  11. R Frederick
    R Frederick
    from illinois
    By your statement and avatar, you have a fascination with peeing in containers. Lol
  12. r8odecay
    r8odecay
    Just make sure you don't fill them full of boiling hot coffee and then grab them in the middle of the cylinder...use the 'insulated' plastic cap and clip to carry them...ask me how I know.
  13. 1971BB427
    1971BB427
    from Oregon
    I've got something similar for my overflow. Mine was a canister of test gas that was tossed out. Pulled the valve and got a mineralac strap from the electrical supply house, then mounted it to my radiator support.
  14. chaddilac
    chaddilac
    Cut the tops off and make some console cup holders.
  15. voetsek
    voetsek
    from Maryland
    Those look like SIGG Bottles. If you modify them for other uses, watch out for the protective coating inside.
  16. It is a consequence of my real fascination....beer.
    This won't make any sense when I change my avatar.
  17. R Frederick
    R Frederick
    from illinois
    Then, don't change it. lol
  18. Finnrodder
    Finnrodder
    from Finland
    I was thinking same thing
  19. LostHope
    LostHope
    If i had the i would throw them in my metal furnace and melt them down to make some car club plaques or aluminum parts or shift knob's:D
  20. Entlebucher
    Entlebucher
    Fuel Tank for a camping stove ;)
  21. dustdevil
    dustdevil
    from illinois
    I pinstripe them and sell them!!
  22. DE SOTO
    DE SOTO
    Here is an idea !
    Reuse them as Water Bottles !
    Or recycle them, They are not Car Parts..
  23. Whiskey comes to mind. I prefer a silver flask but an aluminum water bottle would do me just fine. :D
    I am making an overflow out of an old stainless "Thermos" one of those either painted or polished or bead blasted would work as well I suppose. I like my overflow to hold at east a quart and a gallon would be better for me but I suppose that is just overkill.
  24. Deuces
    Deuces
    I still have a dozen empty aluminum Budweizer bottles stashed in the garage... I planned on using those for something... But I don't know what!..:confused:
  25. Glass? The raven makes ale every year for christmas that he gives out for gifts. he would probably like them. ;)
  26. Cut'em in half polish and insert a gauge ...would make interesting gauge cups..
  27. Excellent. Right out of the box thinking.
  28. Deuces
    Deuces
    That's an idea...
    But I don't think my 2-5/8" Autometer gauges will fit those.. :( Damn it! :mad:
    Oh well...
  29. What's the I.D. of the bottles cut in half..if they are close you may be able to taper the opening a small amount.. Since they are aluminum, which is soft metal they should fudge a small amount before splitting..
    Cut in half insert something like a old tapered center cap from a mag wheel or the metal top from a oxy acytlene bottle....tap gently until desired size is obtained...
  30. I've seen a ton of people use these for coolant overflows.
