Bought two model A's today.
Discussion in 'The Hokey Ass Message Board' started by 1929Essex, Jul 23, 2011.
  1. Bucket of T
    Bucket of T
    those are some cool pictures. sounds like you made out with a good deal. have fun building them!
  2. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    you've got 21's on that coupe it looks like. Paint em and sell em. Last set i saw were $800 for 4
  3. ironandsteele
    ironandsteele
  4. Dean Lowe
    Dean Lowe
    The month/day/year will be stamped on the lower left side of the gas tank, just above where it bolts to the lower firewall. The only time it isn't is if the car got a replacement tank at some point in it's history. It may take some work with a wire brush to find it, but it's there. Also, if the rear fenders are drilled for tail light mounts, it's a good bet they are 29's.
  5. 1929Essex
    1929Essex
    update...i havent done a whole lot, been busy with work and still collecting parts. I am building the coupe, my buddy Mark is building the sedan. As for the coupe, the body is off, started cleaning it up, p***engers door patch is in as well as the cowl. Plan is to use a buick nailhead.
  6. Lookin' good. I'm jealous like everyone else here. Wish my sedan was in that good of shape. Do you plan on choppin' it at all?
  7. Deuces
    Deuces
    Keep up the good work!...
  8. 1929Essex
    1929Essex
    i plan to chop it 4 inches...gotta find those impossible to find roof sections first though. I will probably just end up making them but it will take some time.
  9. Carter
    Carter
    Also, from the couple I've had and seen, a lot of the 29 commercial tanks don't have the stamp. They have the 30-31 type gas cap but are otherwise a normal 28-9 tank
  10. The '28 and most of the '29's had a date stamped into the gas tank on the driver's side under the hood.
    Charlie Stephens
  11. ncrides
    ncrides
    from Mass
    definitely a great score my sedan body was $800 and another $1000 to ship...metal work is looking good keep the pics coming
  12. chopper cliff
    chopper cliff
    from lodi ca
    28-9 the date is stamped on the left corner of the fuel tank, front top section and doors will fit coupe, 28-9 pu doors are actually 26-7 model T coupe and sedan doors and will not 28-9 coupe or sedan, another way is to tell by looking at the front left cowel panel inside it will have a slot on the floor brace for the e-brake handel early 29's had a plate screwed on this slot late 29's were smooth, 28 early 29 had 3 holes on the left lower hardbar with 3 holes for t-lite bracket, smooth on later ones, AR cowel panels were cut flush with firewall later28-9 had provisions for hood welt, these are easy ways to tell. Did you kiss the guy you stole these from? :) LOL
