Have this 31 A stuffed into my shop as a winter project. Nice body but they chopped it too far (and really screwed up the firewall). Anyone have the pieces from chopping their A laying around? Would like to raise it 2 or 3 inches. If I can find the bits, I'll undo the ribbed roof insert while I'm cutting on it.
The top & firewall almost kept me from making the trade but the body is rock solid. With the windshield frame in I can't see out of it.
There is a thread on here somewhere where someone modified the top of the dash, if i'm not mistaken it was an A. They took most if not all of the metal at the dash rail so the windshield frame was about a 1/2" above the cowl when closed. This modification could help with the lack of visabality and save a ton of metal/roof re-work...just a thought.
+1 to the chop looking good. I'd swap it out for an original firewall though, but leave the chop as is! That thing looks bad***.
Firewall ****s bad. Chop kicks ***. Ribbed roof, not a fan. I agree, trade it for a nice unchopped body if thats what you want. Way, way, way less work.
I agree on fixing the chop, 3 to 4 inches is max for a 30-31 model A in my opinion, I also agree on the butchered firewall. But the roof ain't that bad, if you are building a 60's style car that is.
Myself, i'd try to cut a deal with someone who is chopping theirs, take their roof and throw it on yours and your roof and throw it on theirs, that way you only need to weld it in one place
i agree, but if he's going for an early look it may not suit the style to have a chopped roof. if it were me i'd do just as you've said. lost?????
The amount of chop on a coupe is usually dictated by how tall you are and if your going to channel it. If your 5'6" or 5'7" your probably good to go. Any taller and somethings gotta give, especially channeled. In my case my back went first.
Chop looks good? Ribbed roof and all. Why would you even think about raising it? Throw a stock firewall in there and call it a day..
I did that on my '34 pickup. The 32-34 pickups have about a 1-1/2" area between the cowl and the bottom of the windshield frame. I took 3/4" out of mine. I don't know if it's possible on a Model A, the windshield frame is right on top of the cowl.
I agree that the chop is about perfect, I'd modify the visor if being able to see is really a problem. The car looks perfect the way it is. The firewall I'd fix.
34 drag truck build Yes here is the thread i was thinking of, Mat Thrashers truck a couple of posts above, page 6 shows the mod. While yours won't be the same you could do a mod. on the same area to gain some more windshield, again just a thought.
117harv thanks for the link. No question that the firewall will be changed out. I've searched around for a complete roof with no luck. I'm 6'1 so it's pretty tight in there, will only get worse once the floor is in.
