Customs 35 Ford 3-window build
Discussion in 'The Hokey Ass Message Board' started by Fomocokid, Oct 25, 2010.
  1. oldman2
    oldman2
    Both repair look good....Jim
  2. Fomocokid
    Fomocokid
    from Rapid City
    I used 18 gauge
  3. Fomocokid
    Fomocokid
    from Rapid City
    I shortened the steering column tube between the steering wheel and the column drop. This put the steering wheel where I think it should be
    mgtstumpy likes this.
  4. Fomocokid
    Fomocokid
    from Rapid City
    I worked on the steering column a little more yesturday. This is what it will look like. I just have to finish the guts of it now
  5. stlcrzn
    stlcrzn
    Looks cool, will look better with floors and a seat!!!!:)
  6. rustyfords
    rustyfords
    from Conroe, TX
    I want a 30's era Ford coupe so bad it almost hurts.
    Your build just makes me remember why.
  7. oldman2
    oldman2
    Steering wheel looks good, are you going to epoxy repair the wheel, or have someone else repair??...Jim
  8. Fomocokid
    Fomocokid
    from Rapid City
    I plan on trying to fix it myself. There is very few things on this car that I will let other people do
  9. oldman2
    oldman2
    That's what I like to hear. I'm the same way, you're doing a great job...Jim
  10. rusty rocket
    rusty rocket
    Kellan, your not obsessive- compulsive are you? Just kiddin I love to do as much as I can myself, but I know my limits. You make me jealous kid.
  11. Fomocokid
    Fomocokid
    from Rapid City
    I finished the steering column tonight. I put a bearing in both ends of it. i took my steering box apart and cleaned it up.
  12. oldman2
    oldman2
    Did column originally come with bearings or bushings?....Jim
  13. Fomocokid
    Fomocokid
    from Rapid City
    It had a bushing up at the top and the bottom went straight into the steering box so it had a bearing in there
  14. Fomocokid
    Fomocokid
    from Rapid City
    I ***embled the box last night and put it in the car. I did smooth the casting out a little but I didnt go over board.
  15. oldman2
    oldman2
    Looks good...Jim
  16. stlcrzn
    stlcrzn
  17. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Beautiful job resurrecting this one!
  18. Fomocokid
    Fomocokid
    from Rapid City
    Last night I machined the center of my shift knob out so I could put my grandpa's saint christopher medallion in it. I have been working on the steering wheel as well. It should get a coat of sealer and primer this weekend
  19. Very nice and how very cool to put something from your Grandpa in your coupe.
  20. TomH
    TomH
    Did you weld the D shaft on or mill them? I know how you felt about Grandpa, nice touch.
  21. oldman2
    oldman2
    Nice touch and personal all in one....Jim
  22. sbin
    sbin
    Love this build thread the shifter knob put it over the top!
    Nice touch.
  23. stlcrzn
    stlcrzn
    WOW Kellan, what can I say? This brought tears to my eyes!! What an absolutely beautiful way to honor your grandpa. He would be so proud of you! I'm sure he is looking down on you and smiling!!! It also made your grandma cry. She could not believe it.:)
  24. Pop-Rodder
    Pop-Rodder
    God I love seeing young kids getting into this hobby...keeping it alive. Looks like you're doing a pro job, son..stay after it. Being a grandfather myself, the shifter hit home to me...good job. Make us old guys proud.
  25. Rpmrex
    Rpmrex
    from Indiana
    You sure are doing an outstanding job!
    When you said "gap the top of the door" What are you doing to get the gap so nice compaired to where it was after the chop?
    Thanks for the do***entation of this build!
  26. Fomocokid
    Fomocokid
    from Rapid City
    I welded them on. Used the lathe to keep it straight
    I weld on the edge to build it up. where it is a big gap I weld some 1/8 inch stap on. As you tack it you can pull it around the curve. Then I grind it till I get the gap I want. It's a very time consuming process
  27. Fomocokid
    Fomocokid
    from Rapid City
    I finished filling the cracks on the steering wheel. I mounted my mirror. I also had to come up with a way to mount the center of the steering wheel, but I figured it out.
  28. stlcrzn
    stlcrzn
    Really, you were suppose to practice on my steering wheel!! Oh well I gues you will be experienced for mine now!!:D
  29. Fomocokid
    Fomocokid
    from Rapid City
    I had to do mine first that way I can charge you more for my experience
