Battery location in a P/U
Discussion in 'The Hokey Ass Message Board' started by pugsley_22, Dec 13, 2011.
  1. pugsley_22
    pugsley_22
    from DuBois, PA
    Can anyone give me some suggestions or photos for placement of a battery for in my 29 A closed cab pickup. Thought about putting it in the bed but i dont wanna draw attention to something like a battery. I dont have room under the seat either. Any suggestions would be much appriciated.
  2. My battery in my 36 lives in an antique beer cooler in the bed. Run the cables through the bottom of the cooler and everything is hidden. Its big enough for the battery and some left over space for some tools as well.
  3. maybelene
    maybelene
    I had the same problem in my '34 International, which has a shortend bed. Finally installed it under the bed, behind the rear axle. Used a drop down box to remove battery from the rear of the truck and installed remote terminals at the rear of the bed to charge/jump battery. Kind of unhandy to get to, but keeps the bed and cab clear. Good luck!
  4. 41PICUP
    41PICUP
    Mine also sits in an old cooler, use the tray for some tools.
    Looks just right.
  5. DIMMY
    DIMMY
    Wouldn't the beer cooler be in the way when you take a load to the s****pers?
  6. Speedy Canuck
    Speedy Canuck
    You don't have any pictures from when you were setting this up do you? I can visualize how you did it, but want to see how it looks. Sounds like a slick fix.
  7. maybelene
    maybelene
    I'll get a picture and post or pm.
  8. hotrodchevy
    hotrodchevy
    I have a friend who used an army amo can looks cool w/ his jerry cans.
  9. Speedy Canuck
    Speedy Canuck
    Thanks!
  10. fleetside66
    fleetside66
    I used my toolbox that I bought new 40 years ago. There is also some room for tools next to the battery. The two vent holes have since been covered by a old louvered speaker cover. I placed it on the p***enger side for weight balance.
  11. badshifter
    badshifter
    Putting the battery in a box in the bed is not hiding it. It's cute, and maybe clever, but not hidden. You may not have room under the seat for a single 12 volt battery, but maybe 2 6 volt optima or other gel style battery wired in series. Many a space problem was solved that way. They fit in the strangest places.
  12. Mr48chev
    It's not an early truck but I'm building a wood box with boat hardware that will set in across the front of the bed on the 48 this time around to hold the battery, tools and necessary spare fluids and cleaning supplies.
  13. toolman1967
    toolman1967
    I installed my battery under the front of the bed and hinged the boards that covered the battery so I could access it from the top. I can still keep stuff in the bed and access the battery without crawling under the truck. Worked for me and I like the access available to the battery.
  14. Under the floor in my '34. (Said in rap form)
  15. Sent from my iPhone using TJJ ****a!
  16. Shaggy
    Shaggy
    from Sultan, WA
    You could go 2 6v motorcycle batteries, it might fit better
  17. pugsley_22
    pugsley_22
    from DuBois, PA
    thanks guys. youve given me some great ideas
  18. 40Standard
    40Standard
    from Indy
    cut a hole in the floor of the cab, build a box & let it hang down
  19. maybelene
    maybelene
    Finally. As good as I could get them, maybe it will give you the basic idea.
