Uh things growing where they shouldn't be
Discussion in 'The Hokey Ass Message Board' started by roseville carl, Dec 13, 2011.
  1. roseville carl
    roseville carl
    Took my flathead dragster apart today for an engine exchange and discovered this growing in the water jacket ouch. This after only about a dozen runs????? Been using water wetter???
    chevy57dude and rod1 like this.
  2. pinkynoegg
    pinkynoegg
    what kind of water are you using? straight from the tap? I go to the drug store and get the distilled water to stay away from this
  3. iwanaflattie
    iwanaflattie
    smoke it.let us know what you see
    VANDENPLAS and 49ratfink like this.
  4. roseville carl
    roseville carl
  5. badshifter
    badshifter
    Call Mike Rowe.
  6. LowKat
    LowKat
    'bout hyperventilated out on that one
  7. Willy301
    Willy301
    That looks like caviar on a lump of vomit...
    or did you use an egg to plug your radiator like on Mythbusters???
  8. Looks like my ex's Hamburger Helper.
  9. Boyd Who
    Boyd Who
    +1! :p
  10. nexxussian
    nexxussian
    Go to your local airport and see if you can find some homebuilders, ask if they can Alodine those for you.
    Make sure to bake them when they are done to get the hydrogen out (325 f for 2 or 3 hours should do it).
    Don't bake them in an oven you intend to cook food in.
    Should end up a gold color, resist corrosion better and hold paint, if you want to paint it.
    Sand it clean first, or scotch brite (or equivalent non metallic pot scrubber).
  11. Dayzedandkonfuzed
    Dayzedandkonfuzed
    What the hell is that? How does it come to be? Why am I the only one asking these questions?
  12. davo461
    davo461
    It looks like it could use a little BBQ sauce!
  13. Baron
    Baron
    I have heard of "working the bugs out of the motor", but did not know this is what the meant...;)
  14. 41woodie
    41woodie
    Did I miss something here?
  15. stainlesssteelrat
    stainlesssteelrat
    from ms
    looks like congealed wattery oil .
  16. henry29
    henry29
    I don't know what it is, but I have the exact same thing crawling around in my refrigerator right now
  17. Flathead Johnny
    Flathead Johnny
    from MA
  18. Nixer
    Nixer
    That's pretty gross.
  19. ravedodger
    ravedodger
    Looks like pizza. How did it taste?
  20. RMR&C
    RMR&C
    from NW Montana
    yummy........bet it smells good too. I would rinse with vinegar or something strong
  21. roseville carl
    roseville carl
    Has already etched about 1/16 out of the aluminum
  22. Thats why I dont drink the water in Roseville. Its down stream from Colfax...
  23. roseville carl
    roseville carl
    Thanks Tim I needed that......................
  24. First possible prevention is to use a liquid sacrificial anode additive by my best guess. Wix has it in a plastic bottle and it's known to some folks as DAC from another manufacurer. May help, may not.
    Other than that, whatever that **** is is something that will never be a good food or fuel additive. Don't try to fertilize a plant with it either.
    rod1 likes this.
  25. Don's Hot Rods
    Don's Hot Rods
    from florida
    That's bizarre ! :eek: We've started adding water pump lubricant and rust inhibitor to the 50/50 mix of distilled water and antifreeze. Last time we pulled the engine apart it was as clean as a whistle inside the cooling p***ages. We won't fill up another radiator without some in there.
    Don
  26. Or you could just drain the block.....
  27. 1959apache
    1959apache
    +2 on that one, pretty funny
  28. I know you don't have a cooling system but I run soluable oil in my water and don't see anything like this.
  29. Black+aluminum = acid. Something in the water, Carl... THe anode idea should fix it.
  30. greaser
    greaser
    I could just imagine what it would be if you were running an aluminum radiator.
    WOW! Now I got questions....
