Features 1940's period correct hot rods
Discussion in 'Traditional Hot Rods' started by erlomd, Nov 28, 2009.
  1. LSGUN
    LSGUN
    from TX
  2. lorodz
    lorodz
    this is the era i tried to go with mine as close i could enjoy
    kidcampbell71 likes this.
  3. erlomd
    erlomd
    looks as if its the same hang out spot its been going for 70 some years by the same owner...kinda erie actually in a cool way...very nice
  4. erlomd
    erlomd
    you can almost make out the colors in this one...awesome pic...thanks for sharing!
  5. Bigcheese327
    Bigcheese327
    Interesting frame rails on this one. Clearly not "A", and don't look to be Deuce. GM? That up-sweep in the back almost looks home built, though.
    Really cool car. Interesting that it's still got the "A" rad shell.
    -Dave
  6. lorodz
    lorodz
    the one picture with all the sticks in the ground .all them stick use to have all kinds of boats attached to them its an abandond marina near my moms house it is kinda erie there alot of fisherman history but looks period to me ..
  7. 383deuce
    383deuce
    I can't belive that I have never seen this post on here all these years. The very first post by Jimmy B are some of the best I have ever seen in anyones colection.
    Thank's Jimmy & the HAMB
  8. Looks like it maybe a '34 Ford frame.
  9. No worries :cool:
  10. youngster
    youngster
    from Minnesota
    It wasn't uncommon to see a Model A body mounted on a later '30's frame. There was a '30-1 coupe body mounted on a '36 frame in my home town. To clean up the rails he screwed sheet metal covers to the sides.
    Ron
  11. ironandsteele
    ironandsteele
    Some really cool pics in this thread.
  12. smitty city
    smitty city
    So as not to hijack this thread, just posted this also as a new post: Habitual traffic violator stickers.
    Getting ready to make some of these stickers, does anyone have a color picture of one, or know what the original colors are.
    If not, how do yellow letters with black background strike you?
    Here are the samples, two different sizes, sizes posted underneath each one. Please go by the sizes written underneath, as the pictures, although proportional, are not to size.
  13. Bigcheese327
    Bigcheese327
    They look great, although for some reason I want to think they were actually yellow-on-red instead.
    -Dave
  14. smitty city
    smitty city
  15. erlomd
    erlomd
  16. not a badge of honour.
  17. dullchrome
    dullchrome
    from SoCal
    That is a perfect picture !
  18. dirtydog53
    dirtydog53
    from Chicago
  19. Hot Rod Elvis
    Hot Rod Elvis
    So you're saying that you can put an A body on a later chassis?!?!:eek: If so and it looks alright, that would be so much cheaper than a 32 chassis or maybe even an a frame.
    -Cody
  20. bustingear
    bustingear
    This is too clean and pretty for period correct. Nice car but....
  21. youngster
    youngster
    from Minnesota
    I'm just sayin' it has been done. From '35 and up the axle was mounted behind the front spring. Today most don't care for that look. If you look at the pic in post by LSGUN you'll see the radiator is mounted way forward. This was probably done because of a late '30's or '40's front axle. You'll also see the body has been mounted so the rear wheels are centered in the wheel wells. Now look at the gap between the flatty and the firewall. Yep they did some strang things back then but hey it's hot rodding at it's best in those days.
    Ron
  22. youngster
    youngster
    from Minnesota
    A good example of that type of front end can be found on the Elvis roadster.
    Ron
  23. dcraddock
    dcraddock
    Jimmy, are these your personal photos ?? there are some well known cars in there,
    candid shots are always great,thanks.
    Dave
  24. erlomd
    erlomd
    It sure is...
  25. Bigcheese327
    Bigcheese327
    I didn’t spend much time studying the front end initially, but I must agree that the roadster, while not bad, leaves something to be desired from the cowl forward.
    Still, I think a rolling chassis from a ‘35 to ‘40 car could make a decent platform for a Model A. Especially if you pinched the front rails and bobbed them to set the wheelbase at Deuce length, more or less. The spring-in-front axle could be converted to spring-behind with new spring perches in the wishbone and the old ones sawn off the front.
    I’d probably not bother with grafting on frame horns, just hiding things with the radiator shell Rolling Bones style.
    A lot of work? Yeah, but if you get a chassis being discarded by a street rodder, at least you’ll have all the raw material you need rather than having to gather disparate pieces. And probably for less than the cost of a bare Deuce frame!
    -Dave
  26. Rusty Junk Ranch
    Rusty Junk Ranch
    This has to be one of the 'ALL-TIME BEST' threads on the HAMB, suscribed !!!:)
  27. LSGUN
    LSGUN
    from TX
  28. LSGUN
    LSGUN
    from TX
  29. LSGUN
    LSGUN
    from TX
