How to identify a 700R4 trans
Discussion in 'The Hokey Ass Message Board' started by rustyironman, Dec 15, 2011.
  1. Okay, I know stupid question, but seriously I've never had a mouse-motor driveline ever in any of my old cars.
    I got these two transmissions in a complicated trade deal. I was told they are 700R4's but I have no direct experience of how to ID one.
    Thanks
  2. themoose
    themoose
    This might help
  3. nsra_23
    nsra_23
    from Indiana
    the 700's have a rectangular trans pan with 16 bolt's, 5 down each side and 3 across the front and the back. The one on the left looks like it has the provisions for the torque arm from an F-body
  4. They're both 700R4's
    I believe the cleaner looking one is out of an "F" body.
    I can tell you a little more if you have a little closer shot of the other side.
  5. Jalopy Joker
    Jalopy Joker
    so, what are you going to do with them?
  6. Okay, the cleaner one appears to be an "MD8" case and the dipstick tube does seem to be out of an "F" body car. I can't tell on the other ****** what case it has cause it's too greasy but I believe that dipstick tube is from a "B" body car.
    GM made 3 types of cases. They made an "MD8", a "K" and a case with no designation. You want to stay away from the case with no markings. These are the worst 700's built. The cases are weak which leads to warpage and they will have a 27 spline input shaft which is also weak along with its internals.
    I'd go with that "MD8" case unless the other one is a "K" case. These ******s usually have 30 spline input shafts with much stronger internals.
  7. The tennitive thought is to use one behind a 350 V8 in a 55 stude
  8. bigdav160
    bigdav160
    Post the code impressed into the boss on the right rear corner of the case and we can tell you the year and model.
  9. VSO737
    VSO737
    Hi,
    Can you give me that info. Here is the CODE: 3 P F M 1 6 1 P
    Thanks a bunch,
    Mike
  10. HotRodDaddy-O
    HotRodDaddy-O
  11. VSO737
    VSO737
    Thanks for the quick response.
    I guess what I really want to know is the MODEL. I know I have a 4L60.
    ¿Do you think that the "P F" (model) stands for Pontiac Firebird.
    I know that the "M" designates it is a 700R4 and the "161" designates the day of the year and the "P" is the shift.
    I did the research a while back but never found out the designations on the MODELS.
    Thanks,
    Mike
  12. mgtstumpy
    mgtstumpy
    700R (4L60), early 4L60E and later 4L60E (Bolt on bell housing). Note electrical connections on later 2, you need a stand alone computer for these unlike the early 700R
  13. bigdav160
    bigdav160
    I think it's a 1983
    If it was a '93 it would have a round TCC connector. Most likely out of an "F" body (Firebird Camaro)
  14. hot rust
    hot rust
    the cases that have the k cast into them are for a k series trucks and suv's as in k1500 they have a bolt on dust cover instead of one that uses screws to attach it.
  15. BOWTIE BROWN
    BOWTIE BROWN
    KOOL thread , i might go check on some also .thanxz.
    "B.B."
  16. This is not true!
    I have pulled "K" case 700R4's from B-body GM cars like the Caprice and the Roadmonster as well as heavy duty cars like cop cars. I have also found some in 2WD V-6 S-10's.
    Bowtie I thought you jumped ship and went Ford???
  17. The electronics in the 4L60e can be eliminated with a vac*** modultor installed internally. With the exception of the lock-up convertor, the electronics for the 4L60e regulate line pressure like the TV cable does on the 700R4 and 4L60. The vac*** modulator, when installed into the 4L60e, regulates the line pressure. When at part throttle, vac*** controls the modulator and allows for less line pressure. But at WOT there's much less vac*** pulling on the modulator thus allowing for full line pressure.
  18. Okay, update. Both have MD8 on the cases.
    The cleaner one on the number pad on the p***engers rear side of the case is:
    6TNM - Y - 00047520 - 240C
    The greasy one on the number pad:
    7T JM 204B
    Any translations as to year and original application and what/which would be better suited to a non-electronic control application?
  19. greg ducato
    greg ducato
    By my experience those codes correspond with an 86 and 87 Chevy/GMC van. The 87 model will be the better of the two since this is the year GM made a host of durability upgrades to these transmissions.
  20. Fenders
    Fenders
    No, the 93 4L60 has the square three pin connector. It is a 93.
  21. greg ducato
    greg ducato
    Actually, a 1993 could have been either a square or round case connector. LT-1 models had the round connector, V-6 and old style V-8 got the square connector, GM trucks and Vans all got the 4L60E starting in 1993, the p***enger cars waited another year.
  22. JeffB2
    JeffB2
    from Phoenix,AZ
    Some 700R4's may have a bar code sticker on the upper part of the bellhousing on the p***enger side,take the number from it and Google it,I found out I had an '89 core that way.For a 700R4 build you for sure want a 1987-92 core as these have all the upgrades and are still non-computer.
  23. Unfortunately, the bar code stickers are long gone on both.
  24. redoilman
    redoilman
    from iowa
    I cant tell from the photo but is the cleaner of the two transmissions the one with the 1987 code? See if there is a cam lobe shaped casting line that goes from in front of the dipstick hole up through the top oil cooler line and down to where the tv cable goes through. If it does it has the auxiliary valve body. Thats the one you want to use as it will have the better internals to work with and you can hydraulically lock up the torque convertor.
  25. These 700R4's take a voltage source for the lock-up convertor.
    No 700R4's were ever built to be computer controlled.
  26. gimpyshotrods
    gimpyshotrods
    1993 was a crossover year. There were both 4L60's (the transmission formerly known as the 700R4) and 4L60E's installed in that year.
    If it has a square connector, it is a 4L60(700R4). If it has a round one, it is a 4L60E.
  27. greg ducato
    greg ducato
    The 1993 LT-1 used a 4L60 with a round 5 pin connector on the drivers side where one would normally find the square 4 pin connector. The 4L60E also used a round connector, but it is much larger and located on the p***enger side of the transmission.
