Plug wires for 55 Desoto HEMI?
Discussion in 'The Hokey Ass Message Board' started by StuntmanJames, Dec 16, 2011.
  1. StuntmanJames
    StuntmanJames
    from Denton Tx
    What kind would ya recommend? Im having a hard time finding ones with boots that fit down the tubes... thanks for any help :)
  2. StuntmanJames
    StuntmanJames
    from Denton Tx
    Fit lengthwise down without flexing or bending...
  3. caddy-man
    caddy-man
    Datsun 4cyl hemi uses bakalite boots they should work
  4. MercDeuceMan
    MercDeuceMan
    from Indiana
    Depends on whether or not you care about what the boots look like and if the motor is going to stay dry.
    My son has been running bone stock Chevrolet straight end standard wires in his 55 desoto with a 291 hemi for nearly 8 years now. He buys the long wires and custom cuts and re-crimps them to fit.
    He drives his car everywhere, like everyday 300+ days out of the year.
    They are about 1/4 the price of the Hemi wires that have those high dollar custom boots but they do a good job. He has went thru two sets of wires in the 8 years.
    Uses long necked angled needle nose plyers to install and remove off the sparkplugs.
  5. 35desoto
    35desoto
    Also do a search on here - there was a thread some time ago that talked about a certain era porsche plug wire and connector that was dead cert for the hemi's
    Ebay sometimes has hemi wires but zI do not recall whether they have the right ceramic/rubber boot
  6. bob t!
    bob t!
    Taylor 75089
  7. George
    George
    Generic Accel/Mallory will work if you are running the wire covers, if not just ad brake cyl. seals to the wires as you make them up, 68 or so Mopar
  8. 73RR
    73RR
    The expensive part of any Hemi wire set is the insulators and as noted, there are several others, including M Benz, that can be used if you do not have the originals. Just make sure that the wire are long enough. The 426H set is readily available but two of the wires are waaay long and two are waaay short.
    If you are crimping new contacts on random length wires buy a quality crimping plier.
    Also, a boot removal tool is useful...
