Model A hot rod, wiring engine compartment pics??
Discussion in 'The Hokey Ass Message Board' started by BillyBobsSpeedShop, Dec 17, 2011.
  1. BillyBobsSpeedShop
    BillyBobsSpeedShop
    I have a29 ford coupe that Im building with a flatty V8 in it. The car is sitting on a boxed/tube frame. I am trying to figure out how to run my wiring to my headlights with out it being seen or with it being seen and looking good and not like a mess? If any one could show me some pics of how they achieved this that would be great.
    Thanks
    Billy
  2. oldsman41
    oldsman41
    Just an idea here.if you run the wires through brake line tubing under frame and than split it at the crossmember for the other side you can paint the tubing the same color as frame keep it out of sight that way.
  3. BillyBobsSpeedShop
    BillyBobsSpeedShop
    Yea, my fiance's dad had an idea of running 1/2" conduit halfway under the fram to the front of the car. but not sure how that would look? Id rather the wire see than try to hide them and make it look bad?
    I like your Idea oldsman41
  4. scrap metal 48
    scrap metal 48
    Nothing wrong with seeing the wire.. Using period wire and neatly run and tied they can look rather nice......
  5. BillyBobsSpeedShop
    BillyBobsSpeedShop
    where can i get period looking wire at
  6. BillyBobsSpeedShop
    BillyBobsSpeedShop
    where can i get period looking wire? and does anyone have any pics of the wiring being shown in the engine area?
  7. 153624
    153624
    from 916
    Sacramento Vintage Ford
    13clicks likes this.
  8. mediumriser
    mediumriser
    from Ohio
    I built my 30 frame out of box tubing. I just drilled a half inch hole in the top of the frame rail right bellow the fuse block and fed the wires inside the frame. Then drilled a hole on the outside to run to the driver side and a hole on the inside to run the wire in some loom to the p***enger. I used the speedway flexible head light conduit and used clear epoxy and stuck it over the wire and into the frame. I'll get you some pix if you want.
  9. 29sportcoupe
    29sportcoupe
    from arizona
    I like to see it, I used wire from a 49 Plymouth but I bought wire from Rhode Island wire for a bobber I built. Love the old cloth covered wire.
  10. BillyBobsSpeedShop
    BillyBobsSpeedShop
    anyone have anymore pics?
  11. dirtbag13
    dirtbag13
    i had a friend machine me plates out of aluminum and counterbore them for rubber grommets ! we drilled 1 inch holes on the inside of my boxed frame allowing me to pull wiring through the frame ! heres a few pics , even made a bulkhead to run my ****** cooler lines in the frame , even ran gas line inside frame , used braided headlight conduit and ran right into side of frame rail with acess plate on other side !
      41.4 KB
      50 KB
      46.6 KB
      53.2 KB
      37 KB
      49.8 KB
      39.8 KB
      39.2 KB
      52.7 KB
    Rice n Beans Garage likes this.
  12. dirtbag13
    dirtbag13
    i'll try to get some better pics next time i'm at my shop ! i'm very fussy and like everything to be hidden or come out exactly in its place! as far as the headlights like i say i drilled the conduit in the outside of the rail and had an 1 inch hole on the inside allowing me to put the lock nut on the conduit ! i had another set of holes under the cab allowing me to pull wire through the frame and have slack out to solder and shrink tube my connections , once done i pulled the slack back inside and have a small plate w 2 quarter 20 ****on heads that cover the acess hole , designed them to look like a mini lakes block off plate ! 2 holes are punched and threaded on the sides of the acess hole allowing the plate to be attached after wiring is done !
  13. Cover what you will see with asphalt loom. I got different sizes at Napa.
  14. For example. Not an 'A', but they are Model A headlights.
    Sent from my Droid using TJJ ****a!
  15. tommythecat79
    tommythecat79
    For a dirtbag you sure have a clean car man that thing is sweet.
  16. Saxon
    Saxon
    from MN
    Yep, also hotrodcompany has looms and different colored cloth wires by foot.
  17. Tatorboy
    Tatorboy
