32 Heavy
Discussion in 'The Hokey Ass Message Board' started by Termites Ate my Chevy, Dec 19, 2011.
  1. Termites Ate my Chevy
    How do you tell a 32' heavy axle?
  2. Go Here and read. The first picture on the page has 32 and 33-36 axles shown side by side that have been dropped and polished. The top on is 33-36 the lower is the 32 (heavy axle as many call it). Notice the "I" at the area of the spring perch bolts, The "heavy has a much more defined "I" and also the areas on the top and bottom of the "I" is relieve machined as compared to the 33-36 axle does not have the relief maching.
  3. 296 V8
    296 V8
    from Nor~Cal
    There are several variations but these are the two most common ones you’ll find …. They don’t all have the pronounced “ I “
  4. 29sportcoupe
    29sportcoupe
    from arizona
    What were these axles from? I was told this weekend I might have a 32 Heavy on my 29. Not sure of the history but was an old hot rod back in the day.
  5. alchemy
    alchemy
    All 1932 Ford p***enger cars and pickup trucks. If a '32 has a different axle, it has been replaced.
  6. 29sportcoupe
    29sportcoupe
    from arizona
    So a 32 heavy came on all cars? does not sound right to me. So did they heat and drop the 32 heavy axles? Just trying to find out a little more about whats on my car. [​IMG][​IMG]
  7. NealinCA
    NealinCA
    29sportcoupe...yes, yours is a dropped 32 "heavy" axle. Note the pronounced "I" at the perch pin...
    Neal
  8. 29sportcoupe
    29sportcoupe
    from arizona
    So are all 32 axles called 32 Heavy? For some reason I thought the Heavy was a version of the 32. If they are all like this wouldn't it just be a 32 axle? Whats the heavy mean?
  9. NealinCA
    NealinCA
    As far as I know...all 32's came from the factory with a "heavy" axle...but some say that very late production 32's used the lighter 33-36 style axle. I do know that Ford only offered the 33-36 style axle as a replcement part...so if a 32 had a bent/damaged axle...it would then get a 33-36 style axle. I think that is where the light vs heavy thing came about. Saying 32 Heavy is kind of redundant...but that is what they have become known as...
    Neal
  10. 29sportcoupe
    29sportcoupe
    from arizona
    Thanks Neil, I guess I figured wrong. Would have thought it would be called a 32 axle instead of a 32 heavy if they are all the same. Now I know.
  11. titus
    titus
    Theres lots of debate over the what they came in, i believe all 32s came with that style of axle, some people call em a heavy axle, unless we all were around in 1932 and at the ford plant well never know!
    your axle is a "dago" 32 heavy axle, as in ed axle stewart in san deigo droppped it.
    i have a couple dago 32 axles and a couple mor-drop 32 heavy axles and a few ive dropped in my own jig.
    JEFF
  12. Phil Stevens
    Phil Stevens
    pick it up, if you go " ****, that's heavy " then you got one
    wallyringo likes this.
  13. titus
    titus
    actually they are only 2.5 pounds heavier than a 33-36 axle.
    v8-60 17.5 lbs
    33-36 20.5 lbs
    32 heavy axle 23 lbs
    I weight them myself when i did a post on the fordbarn about v8-60 axles
  14. stillrunners
    stillrunners
    from dallas
    quote from the 60's....heavy...man...heavy...
  15. Hemiroid
    Hemiroid
    Hey ***us...or anyone else that can help...
    I have a stupid question...
    Maybe then again the stupid question is the one not asked...
    The axle in your jig is marked front...
    I am ***embling my axle / wishbone this weekend. I don't believe there are any markings on my so called '32 heavy axle that clearly mark front or back...
    Does it matter which side I put towards the front???
    Are these axles [for loss of a better word] uni*** where they can be mounted either way and be correct or is there a definite front and back???
  16. The37Kid
    The37Kid
    ***us, that is a nice looking axle you have in the jig, I really like the way the I keeps its shape in the drop.
  17. tommy
    tommy
    The first thing that I check on an axle is the spring perch hole area. The 32 axle is the only one that the hole area is thinner than the surrounding axle. (recessed) It almost looks like the axle was milled top and bottom for the wish bone to fit. 33 up has a raised boss for the wishbone to slip over. Once you compare the difference from the above pictures you can spot one from 15 feet away.
  18. That seems like good info there...
    So let's see...of the 3 dropped axles on the left in this pic, the bottom one is a "heavy", the other 2 are not? (I see that they are lined up next to their stock versions)
    Just asking because the heavy thing is all new to me...
  19. tommy
    tommy
    Yes that's correct. Without a later axle to compare it to in a flea market, the perch hole can easily identify the 32 axle. Both of mine came from cars that were not previously altered. A sport coupe and a 2dr sedan.
    I don't quite get the fascination with the Deuce axle. Both of my cars have later axles that were dropped back in the day. I could send my 32 axles out to be dropped but then they would be 2011 dropped axles. Not quite the same warm and fuzzy feeling I get when looking at my old dropped axle wondering who dropped them and when they were dropped. I know it was over 50 years ago. I guess I'm just too romantic.
  20. juniorsrodshop
    juniorsrodshop
    from nh
    yeah its very easy to tell the difference... they are a very good looking axle dropped. heres mine in my 32.
  21. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    My fascination with them comes when they are stock, I think dropping a '32 axle kills the look of it completely. . . but that's just one man's opinion.
  22. titus
    titus
    theres no front of the axle, thats just a paranoid friends writing!
    jeff
  23. 296 V8
    296 V8
    from Nor~Cal
    For me when I see a hot rod with a undropped axle even if it sits low overall.
    The big void between the axle and the ground looks odd …. like entire car is to high.
    But i to like an undropped 32 axle .... for sale at a swap meet :D
  24. RGG
    RGG
    Got it! That is the best advise I have heard on spotting 32 axles.
    Thanks.
    RGG
  25. The37Kid
    The37Kid
    By the asking price!:):rolleyes:
  26. hillbilly4008
    hillbilly4008
    from Rome NY
  27. titus
    titus
  28. Brad54
    Brad54
    from Atl Ga
    Are '32 axles the same in p***enger cars and trucks? I just found an I beam with wishbones, but it has old truck wheels and big brakes on it.
    I'll go back and take some pics and measurements if there's a chance it's the "heavy" axle. But if the truck axles are different, I'll save the gas.
    -Brad
  29. 296 V8
    296 V8
    from Nor~Cal
    Pickup yes - Truck no
  30. clem
    clem
    surely the part number embossed into them identifies the year and model? ie B 3010 = model B axle
