Technical Polishing flathead intake stupid question
Discussion in 'Traditional Hot Rods' started by AMC360, Dec 19, 2011.
  1. AMC360
    AMC360
    from Canada
    May be a stupid question but I have never done this before.
    I am polishing a flathead intake and heads and I am wandering after they are finnish should I just leave them or do they get clear coated?
  2. eaglebeak
    eaglebeak
    You can go either way.
    The heads are easy to keep clean as they are fairly flat.
  3. Mike51Merc
    Mike51Merc
    I've done both. Clearcoat got stained brown from fuel leaks and had to be stripped. Plain intake oxidizes over time, but that adds patina and doesn't look bad.
  4. Eaglebeak hit the nail on the head, if your going to run an old intake with older style carbs, their going to leak and then you have an issue with the clearcoat.
  5. AMC360
    AMC360
    from Canada
    I think I will just keep them bare metal, thanks for the info.
