I want to do some pre ***embly painting. I have to use waterborne and I like slicksand. Are these two compatible ? Or should I go epoxy primer/sealer and waterborne. Kinda stumbling along but having fun!
Go with the epoxy primer /sealer. slicksand is a polyester ,like bondo and is fairly porous and tends to absorb water. I find painting over slicksand is best if using a single stage solvent based paint. You can use slicksand as long as you put a sealer over it before your water basecoat. Make sure all bare metal spots are covered. Water+metal = you know! I have been in the industry for 27 years and was recently a tech rep for Sikkens. Good luck and Merry Christmas.
Auto air requires a sealer over your substrait then the color over the top of that...all of the nitty gritty details are located on their website
Sealer is a must. The slicksand will also absorb the pigments from the color coat and will turn it blotchy later.
