I need to raise my '58 fairlane front end. do 60-64 galaxie coils raise it?
Discussion in 'The Hokey Ass Message Board' started by luvzccr, Dec 25, 2011.
  1. luvzccr
    luvzccr
    someone told me on my build thread that front coils from a 1960-64 galaxie would raise my 58 a few inches. right now i have the 460 swap and the crites restoration headers are slammed to the ground. i need to raise it a good six inches or so. when i bought my 58, it was already lowered, coils were cut.
    i was thinking maybe just stock v8 springs from a 58 fairlane, but i need more height than the stock springs. any suggestions or opinions if that would work?
  2. grm61
    grm61
    from Washington
    Good to see one going up instead of down:)
    I'd probably try some new HD v8 springs.
    Heres a good link to engine weights to help you decide...
    http://www.team.net/sol/tech/engine.html
    Keep in mind that if your 460 has a alum intake youve already dropped about 50 pounds off of it.
  3. luvzccr
    luvzccr
    will any heavy duty v8 coil spring work though? are coils different sizes or anything? because i'd hate to fork out the money for them only to realize its not gonna fit. i wish i knew someone who raised their 57 or 58 ford in the front and what springs they used
  4. 58custom
    58custom
  5. luvzccr
    luvzccr
    perfection. love it! so you used the HD coil springs? any particular one? i googled it and it took me to ebay, and i found a number of them
  6. Check out the Willys grille on that old Ford.
  7. 58custom
    58custom
    I got a vague description of "mid-1960s Galaxie springs" from the guy who built it. I ended up cutting a coil off each to get some suspension travel as it was against the upper limit all of the time. Try big block 64 springs.
  8. 58custom
    58custom
    Get yer cott'n pick'n peepers offa mah grill! Ya can't have it!
