Hey Guys, I have a problem understanding why my bench test will not work. I have 3 power window motors that I am trying to test. 2 are new reman,s but I do not want to put everything together untested. I have a re wire and a yellow wire very simple. I have a probe tester that will supply 12 volt power. I ground the body and touch the probe with power to either lead on all three motore and I get nothing. I have even used jumper cables to provide a ground and nothing. I am sure I am doing something wrong but hell I must keep making the same mistake over and over because I keep getting the same results. OK what is the best way to do a bench test and know for sure everything is correct ?
Ford power windows work on reversing the flow of electricity, power to red and ground to yellow, goes one way, reverse the wires and it goes the other way.
