'21 steel roadster body
Discussion in 'The Hokey Ass Message Board' started by youngster, Feb 1, 2011.
  1. youngster
    youngster
    from Minnesota
    Had a good day the other day. 4 hours of work in the shop got me $200 and this;
    Ron
  2. rustydusty
    rustydusty
    Sweet! didja get the turtledeck?
  3. youngster
    youngster
    from Minnesota
    Already had one. Guess didn't mention it came with a good ***le too!!
    Ron
  4. youngster
    youngster
    from Minnesota
    Here's the parts box that came with it.
    Ron
  5. Streetwerkz
    Streetwerkz
    lucky duck!!
    good score
  6. The37Kid
    The37Kid
    All you need now is a parts catalog from Lang's! Nice find, what are your plans with it?
  7. hasty
    hasty
    Congratulations!
  8. youngster
    youngster
    from Minnesota
    Future plans for it are a little sketchy right now. I really like Bent's build, the old old school soup job. Maybe get the body straigtened out a bit and go from there. I really don't need amother project right now but ........
    Ron
  9. T Hudson
    T Hudson
    Thats pretty cool. How about a flattie?
  10. butch27
    butch27
    Ron: If you need any frame planes for that you can buy some from Canada.LOL
  11. youngster
    youngster
    from Minnesota
    Thanks Butch ... that's just what I need ... lol
    Ron
  12. youngster
    youngster
    from Minnesota
    I was poking around the ol' girl this weekend and felt sorry for her. Thought maybe a patch or two would cheer her up. Here's what it ended up lookin' like. i think I saved about 60% of the cowl pannel. It is the worst piece.
    Trying to get it to the point where a good coat of surfacer will level it out.
    Ron
  13. looks good Ron, i have to stop over and check it out
  14. woodienut
    woodienut
    from So.Cal.
    Always amazed at how much is still around.
  15. youngster
    youngster
    from Minnesota
    Nice collection of parts wooodienut. A little bit of all the styles and years.
    Ron
  16. youngster
    youngster
    from Minnesota
    Went back and attached the adjacent pannels last night. Everything fit pretty good except for the door. It's got a bit of a twist to it. There's another one coming that won't need as much work to make it usable.
    Ron
  17. steel rebel
    steel rebel
    Good luck it's a journey.
  18. youngster
    youngster
    from Minnesota
    Scored a '29 A ch***is today! Motor turns over by hand. Drained the oil and it looks nice and clean with no metal in it. Got a set of 21" wheels, 5 in all. They seem to be straight, only one with bent spokes. Can't wait to dig into it.
    Let the fun begin!!!!
    Ron
  19. studematt
    studematt
    That pile of touring parts look very very familiar.
  20. rusty28a
    rusty28a
    Go to it Ron! We're rootin' for ya and look forward to the pics. Rusty
  21. youngster
    youngster
    from Minnesota
    Got a chance to go thru the parts bucket that came with the ch***is today. It's amazing. The brakes work just fine. pulled the dizzy and it needs a new cap otherwise it's nice and tight. Clutch seems to work with ease. Gonna make up a contol pannel to mount on it and get'er runnin.
    The axel ***embly was a nice bonus with the ch***is, it's from a '41 Ford. Sold off the spindles and brakes today for $335. Paid $575 for the ch***is so I've got $240 in it. :)
    Ron
  22. youngster
    youngster
    from Minnesota
    Because the body had no sub frame, I started to make a replacement out of wood like it was originally. There are a lot of stress cracks in the sheetmetal. I felt there was no reason to set the car up for more so I made a sub frame out of 16g CRS. This should also help getting the right shape to the patch pannels on the bottom 4" of the body.
    Ron
  23. captainjunk#2
    captainjunk#2
    pretty neat score should be a fun lil car , keep posting photos of your work
  24. youngster
    youngster
    from Minnesota
  25. youngster
    youngster
    from Minnesota
    An up date on the T's progress.
    I had another A frame that was in pieces so I used the rails from it. The T rear xmbr will now be the front xmbr. I slotted the front and welded a 1/2" plate in it at 7 degree angle. It worked out good. I've got 5 degress' with the ch***is loaded.
    The center xmbr was narrowed to 23". Now the rails are 23" from the front xmbr to the center xmbr. I left the stock kick out in the A rails.
    The rails where cut at a 45 and the back section was welded to the top of the front section. They where capped and boxed also. This is a pic before welding.
    Here it is all welded.
    My finger's tired. More later.
    Ron
  26. youngster
    youngster
    from Minnesota
    About the middle of Aug. I recieve a notice for the F.A.S.T. meet in Northwood Iowa. And decided to take the ch***is down. As A result there was a lot of undo***ented work done.
    I wanted to keep the wishbone intact. Since the front axle is mounted in front of the xmember and the motor was set back 2 1/2", I had to extend the bones 8". I just used a second wishbone and spliced it in. This caused a clearence issue with the flywheel housing. A 3/4" aluminum spacer for the ball cured that problem. The next glitch was with a reversed eye spring, the frame sat on top of the tie rod. Replacing the stock main leaf yelded 1/2" clearence. Still not good but it went to the show that way. I have a pair of '33 spindles now to swap in. More on this later.
    Knowing the 4" frame kick would still leave the back too high, I move the Spring down in front of the axle. A tab was welded to the axle and a 3/8" plate made to reach forward to the radius rod. A lenght od 7/8" DOM was welded thru the bone to accept a 1/2" bolt. This all worked well except I now need a shorter main leaf for the rear spring. What you see here is something I cobbled up till I get the new main.
    I will be running the stock A mechanical brakes with a floater kit in stalled. I shortened the brake bellcrank about 4" and built mounts on the outside of the frame rails as Brent did with his build.
    A quick coat of black paint and a few hours ***embly and it was off to Iowa.
    Ron
  27. SaucyNordicTart
    SaucyNordicTart
  28. youngster
    youngster
    from Minnesota
    When I got the body, there was no wood left in it. I thought about building a wood sub structure but my strength is in metal working and not wood so I had some 16ga. broke into C channel and Z channel. Armed with a set of dimensions (which where wrong) I used some 10ga. to fab the firewall mount.
    Time to start repairing body panels next. I started with the p***enger side cowl. It was the worst piece as you can see in the pic.
    Added the top cowl panel and door for effect.
    At this point I had some other folks stuff to work on so ..... it went on the back burner fro 6 weeks.
    Ron
  29. youngster
    youngster
    from Minnesota
    Had to make some room in the shop to work on a customers Model A speedster today so I rolled the ol' girl out side for some fresh air and pic's. Hopefully I can get back to playing with her pretty soon.
    Ron
  30. FlynBrian
    FlynBrian
    Man that is Cool! Nice job!
