Where is the VIN located on a 34 Dodge Pickup Truck
Discussion in 'The Hokey Ass Message Board' started by RustyNCA, Dec 29, 2011.
  1. RustyNCA
    RustyNCA
    I need to get a VIN verified on my brothers 34 Dodge Pickup. I looked for it and can't find it.
    I would like to help him get this bad boy on the road again.
    Thanks
    RustyNCA
  2. 2deuces64
    2deuces64
    Look on the driver side frame rail. It is in the side and to the rear if I remember right. The #'s are about a half inch high and not very sharp. It will take good light and good eyes.
  3. stevorunner
    stevorunner
    I have a 1940 Dodge and its a serial number located on the p***engers side door frame rail
  4. RustyNCA
    RustyNCA
    Inside the engine bay, or along the outside frame rail?
    So I may end up cleaning off all that paint that has a rough finish along the frame in the engine bay.....
    Thanks
    RustyNCA
  5. Originally they were registered off the engine numbers, but also on the door post rt side.
  6. hot_rod_bones
    hot_rod_bones
    from topeka, ks
    my 34 dodge sedan is on the door pillar, riveted in place.
  7. 32Tudor396
    32Tudor396
    I have a 33 dodge coupe and have not found serial either,I have looked all over both sides of frame.On fire wall there is a tag with DPRS and the number 48 stamped for body.What does this mean?The car was origionally from Winnipeg Man.Canada.Are canadian car serial in same place?
  8. dave lewis
    dave lewis
    from Nampa ID
    On my 30 dd 3 window coupe....
    On the drivers side frame rail, just above and slightly forward of the shackle mount for the rear of the front leaf spring.
    2 duces has it right...about 1/2" tall and faintly stamped...
    I had to wire wheel it and then rub soapstone on to be able to read it..
    good luck
    Dave
  9. Fat47
    Fat47
    My owners manuel for my 33 Dodge coupe states it is located on the door pillar.
  10. Samster
    Samster
    from Belgium
    I have a '35 pickup, front left on the cab, engineside was the plate,
    rightside of the ch***is has the numbers hammered in, lightly and nearly fading..
  11. Samster
    Samster
    from Belgium
    and DAMN! I want your frontfenders!!
  12. filthy frank
    filthy frank
    on the P*** side b pillar on the body , and on the the front face of the frame drivers side inbetween the cowl and the front crossmember .
