Does anyone know where I can get the spring and plastic plate ***embly for the electric choke for a rochester 2GC carbureter. The one on my tri-power isnt working right. Thanks
Any reputable parts store should be able to help you (they may have to order it in). Get the carb number (7024211 as an example), when at the parts store have them look up individual components by the carb tag number. Choke thermostat, is the proper name for it. Or, post the carb number on here, and either I, or someone else, can get you an aftermarket part number, they can use.
Contact Larry Fulton at Automotion Rochester Carburetor Service. He is a HAMB member. He is the best for 3 deuce setups and parts. http://www.hotrodcarbs.com/parts.php?Carburetor_Parts
NAPA P/N 230125, CRB is the line code. It is for a Carter carb but works good for me. You can view it on NAPAonline.com
