Bought another Model A Pickup
Discussion in 'The Hokey Ass Message Board' started by A Rodder, Dec 31, 2011.
  1. A Rodder
    A Rodder
    Ill post picks soon.
    My first question is the Vin number on the block. There is not one, it is smooth cast like.
    Not filed or ground down, like it was never stamped.
    Reason I ask is I have to file paperwork for the ***le which requires a Vin inspection.
    We all know where the Vin is and the dmv lady said if the engine number matches the Vin I have on the registration, she would let it fly.
    Would there be a reason there is no number there, factory replacement motor?
  2. RB35
    RB35
    I believe Model A #'s are on the frame only. Not sure when they also added the # to the trans, but never on the engines.
    RB
  3. A Rodder
    A Rodder
    I was for sure that it was there also, someone should chime in soon.
  4. 067chevy
    067chevy
    Vin number was always on the engines in Model A's starting in 1928. Maybe replace with commercial or ag engine.
  5. 067chevy
    067chevy
    Check the frame under the cowl on driver side of frame.
  6. A Rodder
    A Rodder
    It was a one owner until the Dad past away a few years ago, I got it from the son.
    Stored since 1965, not always in a barn.......
    It has rust in the usual places but it is 100% complete from what I can tell.
    Already has 16 inch wires on it, with an additional solid 40's era steel wheel.
    It has oil in it that is a little murky.
    I literally just walked in and loaded the picks.
    I don't have too much plans for it. Basically clean it up and get some rubber under it.​
  7. F&J
    F&J
    If it's important enough to you, I'd also lift it to verify. Lot of work, but....
    I would not lift the body if the rest of the frame has too much rust like here in the Northeast...because it won't be readable.
  8. woodypecker
    woodypecker
    It should be on that little non red spot in picture number 7. Maybe if you wish hard enough a leprachan might stamp it when no one is looking.
  9. tfeverfred
    tfeverfred
    Wouldn't those numbers be raised?:confused:
  10. lump
    lump
    Hmmmm...I can't THINK of another car type, than early Fords, for living long useful lives, and for having so many vehicles getting engine swaps done to them over the years. How could a DMV bureaucrat expect and require a 75-year-old Model A to have its original motor in it? In the late 1940's, early 1950's you could find ads all over car magazines offering Model A, Model T, and V8 Ford shortblocks for cheapo prices. THOUSANDS of motors were exchanged. Wow.
  11. voodoo1
    voodoo1
  12. A Rodder
    A Rodder
    I am really trying to avoid lifting it. We will see.
    Can someone confirm as to wether the number would be stamped in or cast out?
    The motor in the gray 30 has the raised area ground down so I can't use it for reference.
    But I just realized the green coupe should have it, ill check there in the morning.
    Anyway it is a pretty cool little pickup.
  13. A Rodder
    A Rodder
    The dmv doesn't require it to be original, but if it is and its was stamped matching the Vin on the 47 year old registration renewal, that is good enough for her to believe that that vin# matches that vehicle. And in turn saves me a lot of headache.
  14. caseyscustoms
    caseyscustoms
    from st.joe, MO
    wow thats cool, get it running and leave it just like that.
    running, car wash, driving, chase *****.
    repeat as much as necessarily.
  15. Bad ass fords
    Bad ass fords
    Love those old truck nice find!
  16. BlockBuster
    BlockBuster
    from SEMass
    A number, matching or not, should be found stamped on the motor. I recall that the A motors were numbered and shipped to their final ***embly factories and the frame was then numbered to match.
  17. the numbers are stamped not raised
    if its a b block they never had numbers stamped there
    if you have to raise the body and the numbers dont match then you have a whole new can of worms to deal with.
    not saying i would ever do this, but save yourself alot of h***le and stamp the numbers in the block
    tk
  18. The engine number will be stamped and should have a star at the start i'm pretty sure.. but could be at the end. It'll be on that spot that was mentioned before.
  19. pug man
    pug man
    from louisiana
    You sure got some nice iron to work with. Congrads on a nice survivor......
  20. 067chevy
    067chevy
    get some stamps and stamp the number on the block. Problem solved.
  21. 067chevy
    067chevy
    The number would be stamped
  22. LowKat
    LowKat
  23. A Rodder
    A Rodder
    I better check there again, maybe I need to look a little closer, maybe it will be there!
    I have a tudor and the chopped coupe, and a 56 nine p***enger belair. I really don't need another one. I just couldn't let it go. The grey one in one of the pics is slated to be a fresh arrival to Austraillia very soon.
    I'll keep it for awhile and then send it down the road. But at least it won't get parted out.
  24. gimpyshotrods
    gimpyshotrods
    This is correct, per Ford's on historical records. If it has no number, then it is a replacement engine, that did not come from the factory in a car, or it was from a piece of engine-powered non-car equipment.
  25. hotrodA
    hotrodA
    Stamp the number!
    Or pull the floor board and see if it's
    stamped on the top of the flywheel
    housing.
  26. gimpyshotrods
    gimpyshotrods
    If you do, just DO NOT tell ANYBODY you did.
  27. fullthrottle53
    fullthrottle53
    Neet project. Do you want to sell it? Need more brains!!!!
  28. A Rodder
    A Rodder
    I will have to look there, will it be obvious like they are on the block?
  29. 53olds
    53olds
    Sigh...Joe we need to have a talk about this! LOL 4 Model A's!!!
