Making A 671 Rotor
Discussion in 'The Hokey Ass Message Board' started by Dzuari, Dec 27, 2011.
  1. Dzuari
    Dzuari
    from Muncie, IN
    Its about that time :)
    Making A 671 Rotor Build Thread
    Day 1
    For anyone that doesn't know me or reading one of my threads for the first time you can check out the build thread of the 671 Blower housing here @
    http://jalopyjournal.com/forum/showthread.php?t=636663
    and you can also keep up-to-date info on our builds and what we are doing, or just show your support for an American manufacturing company by liking us on Facebook @
    https://www.facebook.com/DiamondPRacing
    Check out all our latest videos @
    http://www.youtube.com/user/dzuari?feature=mhee
    Making A 671 Blower
    <iframe width="640" height="360" src="http://www.youtube.com/embed/zU34no3VLHI" frameborder="0" allowfullscreen></iframe>
    O and if anyone is wondering, our machines are still tied up doing some jobs so we are still on hold for creating the fixtures for the blower housing.
    Ok, so just started drawing of the rotors today, this is what i've got so far, 3 lobe 60° helix. Now these drawings are currently of the casting, not the finished machined rotor.
    You can see in this photo the coring and hollowing out of the rotors, now when the pattern is made, i will be designing this to accept different size cores, that way we can have different coreboxes that will all fit the same pattern, this way we can create different internal designs for strength and weight to test which works best.
    Looking down the barrel
    I've designed this rotor so that i can just change around a few things and create different helix rotation degrees or bore sizes.
    Cross section of one lobe
    Thats it for now, need to do some other stuff for the day. I will have some more photos up tomorrow and if people badger me enough i might post a video or two of the designing of the rotor :).
    If you have questions, feel free to ask.
  2. Dzuari
    Dzuari
    from Muncie, IN
    Day 2:
    Just doing some final checking on the design. Going to be heading over to my Uncle's to discuss with him the best approach to making the cores and pattern for this thing, we have a few different ideas on the best way to do this.
    Clearance checking and motion simulation to make sure everything fits right, this is for a 5.8" bored case. These rotors are machine cut to 0.025" from the case walls right now but that is all variable and can be changed when machining is done, really im just making sure everything fits right, these are just the preliminary designs and are not the actual finished machined designs.
    And just to see what it looks like, i threw in a 120° helix variant
  3. gas pumper
    gas pumper
    Once again, thanks for the details, this is great.
    I didn't realize the need for core supports. I never looked inside a GM rotor, did they do this, too?
    Are you going to machine in the tip rib on each rotor? I would think that would allow closer clearances. And if there was a heat expansion issue than only the rib would rub and save the blower from locking up.
    Thanks
    Frank
  4. kma4444
    kma4444
    Fantastic as usual. Please keep them coming.
  5. Dzuari
    Dzuari
    from Muncie, IN
    Yes they have them, you can have the lobe cores and center core separate from each other but it would require some sort of support and i would be worried about it shifting to much.
    We will have the tip rib, these drawings are not the finished machined surfaces of the rotors, im just checking for basic clearance. The actually geometry of the finished rotors is a bit complex but is just like designing a gear. When you add the tip rib you have to cut away the back side of each lobe for clearance, but it results in less overall surface contact but you still get the same(or close to) amount of seal.
  6. Dzuari
    Dzuari
    from Muncie, IN
    Day 2.1:
    Here is one corebox design, 3 pieces that pull away from each other, this way the core will be all made in one piece, no gluing together. This way we dont have to worry about core shift as much.
    Here are the draft ****ysis of the coreboxes, everything that is red is negative draft, this is the complications you get into with a helical core, but i can fix it.
    360° helix :) this wouldn't hold compression though, unless i move and changed the inlet and outlet ports, would look a lot like a twin screw :).
  7. Dzuari
    Dzuari
    from Muncie, IN
    Day 4:
    K, im been up for 27hrs now working on this :), sry if i miss some stuff but here is a fully ***embled blower, The case is still just casting though, i haven't cut the machine stock to fit with the plates.
    The gears and rotors are all clocked and in line with each other, this however is just a scaled version of the blower, i will be printing all this out on our 3D printer and using some 1inch bearing to slip into the plates, ill hook a electric motor up to it just to see it run.(i know the rotors don't have the top ridge cut in them)
    For Anyone looking to get something made
    Now, something very interesting that i know a lot of you will like. A lot of you have messaged me over getting a quote or idea on how to get your idea into a casting or machine part. Usually i give you an idea of what it would take and the cost, but, we have been discussing getting into investment castings and this is going to open up a whole new area of work for us and drop the price way down for anyone looking for one or two off castings.
    What this means for anyone looking to get something made, all you need is a CAD file(model), you can send it to use, we can send that straight to our 3D printers, then take that printed part and dip it in the investment slurry and pour you a casting :).
    Now currently we just have just have our 1 printer and the material for it is somewhat expensive and if i get 200 emails from people wanting stuff made then its going to be ridiculously costly and a long wait period, so for now hold you emails. but, i am currently working on building another 3D printer, once i get it lined out and running the cost will drastically drop because the material is very cheap, im guessing less than $100 to print out a v8 head(1 bank) but dont hold me to that :).
    Once i have the one printer running, i will be able to print the majority of parts needed to create another printer, its designed to self-replicate :), and of course i will do***ent and video it all, that way anyone that wants to can make there own then just send us ur models and we will cast them.
    Here are some pictures of our fixtures being set up on our 2 pallet brothers, this is a high speed vertical, 16,000rpm spindle. We cut these pulls in 12mins 100% finished :).
    The orange clamps are actually 3D printed
    k, no im going to bed
  8. Dzuari
    Dzuari
    from Muncie, IN
    Day 5: Sat. 12/31/11 Feels great to sleep for 18hrs :)
    Came in today to check on the 3D printer, here it is printing a 1/2 scale blower, the gears and couplings are not what we will actually be making :), i just changed them so i can slip different 3D printed couplings on and off that will be attached to a small electric motor. The photo is a bit blurry because i took it through a plastic window, the plastic is actually extremely detailed. I make a video of it once i have it put together and running.
    Here is what the final half scale will look like. Also, the case is actually what our full scale cast cases will look like, (no more giant ears off the sides), they will be machined to fit exactly in line with our plates.
    P.S. I can print out and sell 1/4 scales if anyone is interested in buying a plastic blower :) something cool to sit on your desk. If anyone interested just say so on the thread. Ill figure out how much one would cost if anyone is.
  9. m.kozlowski
    m.kozlowski
    That would make awesome conversation piece in my garage :) I would like to know the cost, but sign me in for one :)
    Dzuari, Your videos and photos are great. Even my little kids are interested in casting stuff right now :) Thanks for sharing.
  10. Put me down for a plastic one.
    Im loving watching this come together.
  11. Dzuari
    Dzuari
    from Muncie, IN
    Day 6: Sunday 1/1/2012 "The Power Surge"
    Mini Blower Info:
    Just to let everyone know that is interested in buying a mini blower, just want to make sure that you know that it will be printed out of ABS plastic and not be metal, so i Do Not recommend you hook it up to anything and actually try to run boost off of it :)(like a race lawmower for whoever said that :)). So, i highly advise against any such actions, but, in the event that you disregard my warnings, please upload a video of what you did because i would love to see it.
    this week i will scale it down to what i think would be a reasonable price for one, this material for this printer isn't cheap though so we will see.
    Also all the mini blowers that we do print will be this color orange, we use orange mostly because its easy to fill in and sand and see any defects when we print parts or tooling from it, and it also its reminds me of my duster :). I will however put a bit of clearance on everything, that way if you want, you can paint the blower to what ever color you want. I've actually seen some 3D printed stuff that looks like the real thing if you paint it right.
    Now onto the cool stuff.
    First pallet of 2 done printing.... well half of it is done, something happened and threw off the printers coordinate system, you can see that the blower housing and the gear with the shaft running off of it has shifted to the right about half way up. A power surge probably caused this, the printer screws up every time we have one, i need to buy a battery for it.
    Parts broken off the pallet, the black is just support material, it will dissolve in a cleaning solution you're about to see in the next picture. Everything that is printed is an exact scale of the models directly used in all of our patterns and production machining. To be exact, they are 51.5% of the full size versions,( i had to match the bearing bores to some bearings i bought online).
    Here is the solution, its really just water with some industrial strength oxy-clean.
    I am starting the printer up now to print the rotors, rear plate and cover now, ill have to print the tall gear and housing again also, but that will be on pallet 3. Once i get the thing put together and turning ill make a video and upload it and have a price for some Mini's.
    DIY 3D PRINTER
    Also, if anyone has been read about my post of making my own 3D printer or seen my video over everything that i am doing on my youtube channel here
    http://www.youtube.com/embed/cJ20Yoq5LNY
    i have ordered it, it just shipped out of Canada yesterday and should be to the shop by this week. I will be video everything i do to create this printer and how anyone else can to, mechanics, electronics, software and programming behind it all.
    The reason im doing this though is because one, we can use it at the shop, but two, it will give me the knowledge and experience i need to build my own CNC machine and Wire EDM machine, all of which i will be videoing too.
    If you want to read more and learn about the 3D printer i will be building you can check out its website @
    http://reprap.org/wiki/RepRap
    RepRap
    I will be building the Prusa Mendel version, it is the cheapest and easiest/newest to build. you can google or youtube videos on the printers and find tons of info on them. The idea behind this particular printer though, is it is all freeware. people that build, designing, and modify stuff from these printers all share their creations on websites for free, all you have to do is download the model and print it.
  12. Dzuari
    Dzuari
    from Muncie, IN
    thats great! i love seeing the younger generation get interested in how things are made.(i say that like im old :)) Some of them have to learn it though because they are the future and if you don't p*** the knowledge down it will only hurt you or your kids in the longer run.
    If they are really interested in doing it, i don't know how old they are, but you could help them build their own 3D printer from the videos i will be posting on building mine. A lot of times the younger generations are a lot more tech and computer savvy than the generations before them, they could probably do all the electronic and computer stuff while you probably wouldn't have a problem with the hardware and mechanics.
  13. moefuzz
    moefuzz
    Awesome Stuff!
    Thanks for taking the time to post this.
    moe
  14. Dzuari
    Dzuari
    from Muncie, IN
    Also, if anyone is interested in making their own 3D printer, i bought mine from this website,
    Prusa Mendel Full Kit (Excluding Printed Plastic Parts)
    This was the cheapest i could find on the net, and the kit comes with everything you need to build one, Except for the 3D printed parts. If you read a bit about the repraps, you know that they are designed to print a majority of their own parts, they self replicate. You will also need to buy the 3D printed parts along with this kit.
    I will just be printing the parts out of our 3D printer here at the shop, i can see how much it would cost to print the parts and sell them to anyone that wants them, but it will probably be cheaper for anyone else to just buy them on a dedicated reprap vendor site.
  15. Dzuari
    Dzuari
    from Muncie, IN
    Day 7: Monday 01/02/2012 "the Honeycomb"
    3D printer is half way done with the rotors, im crossing my fingers that we dont get a power surge or anything to screw it up. We had today off for work, i just came in to check on the printer and get some pictures, tomorrow i will start scaling down the blower and see how much a 1/8 and 1/4 scale will cost.
    The parts that were printed on pallet two, all the support is dissolved out of them and now just have to wash them in the sink and wait for them to dry.
    Here you can see how the printer screwed up and shifted everything
    And since the printer screwed up i had to stop it so you can actually see what it looks like inside a 3D printed part. It is actually a honeycomb inside and i can control how thick the outside walls are, i can also print in full solid but heat and warpage can become a problem in larger parts. Printing honeycomb saves a lot of weight and material(cost) but it means that the plastic becomes porous and will retain liquid, not a big did for just prototyping and checking things.
  16. Dzuari
    Dzuari
    from Muncie, IN
    Day 9: Wednesday 1/04/2012
    3D printer is done with the rotors, rear plate and cover, now just need to reprint the housing and long gear that it screwed up earlier.
    Here is our latest work on our pulleys, Turned on our mazak lathe, holes and teeth machined on our highspeed brothers and back to our lathe for some final polishing, here is the finished product.
    You can check out a few more photos or possible buy one...(we'd really appreciate that :)) @
    http://www.diamondp.com/8MM_X_53_TOOTH_POLISHED_DRIVE_BELT_PULLEY_p/dp-0022-101-000.htm
    Mini Blower Update
    For anyone interested in one, i have the design done on an 1/8 scale version of our 671, calculated our cost and am discussing a price right now, my guess is that some of you wont be to happy on the cost though :/.
    Added helical gears though, hopefully should help be a bit more quiet
  17. Dzuari
    Dzuari
    from Muncie, IN
    Did some graphic rendering of the full ***embly, took my computer 5 mins to generate each of these photos and for those of you who want to know, im running an i7 quad 8G DDR5 with a geforce GTX 560M 2G DDR5.
    Also these photos are of the 1/8 scale, not full 671, thats why the coupling looks wonky
    Chrome
    Polished, not much difference
    Couldn't get this one to turn out quite right, shouldnt' be so dark, the top face should be machined finish and the bolt holes should have been machined spotface
  18. Dzuari
    Dzuari
    from Muncie, IN
    here is some renderings without the case
    Factory floor
  19. Dzuari
    Dzuari
    from Muncie, IN
    Day 11: Friday 01/06/2012 "Bearings In"
    Bearings for the plates came in today, they had a little lip in them that i didn't expect but didn't take long to grind them down and press them into the plates.
    Housing has 6 more hours before its done printing then i can ***emble the whole thing and ill make a video of it running, will also be releasing the price on the 1/8 scales.
    Housing printing
    Prusa Medel parts also came in today, it feels like christmas :)
  20. PBRmeASAP
    PBRmeASAP
    Ok, i'm seeing single groove v belt pulley...didn't see them on your website, are they for sale yet? I'll be needing one really soon.
  21. That is brilliant!! Would love to be able to build my own blower, what a great talent!
    Doc.
    P.S. Add my name down for the plastic mini blower!
  22. Dzuari
    Dzuari
    from Muncie, IN
    We have a few completely machined i believe but we are waiting till we get the fixtures made for them to put them up for sale. If your needing one really soon though you can message me and we can probably sell you one.
  23. Dzuari
    Dzuari
    from Muncie, IN
    Day 12: Saturday 01/07/2012
    Housing was finished last night, threw it in the wash about 10am, been washing for 10hours and almost done, going to let is sit for the night and come in and check on it, then its ready to ***emble.
    10hours later
  24. Dzuari
    Dzuari
    from Muncie, IN
    Day 14: Monday 01/09/2012 "The Mini"
    The half scale is done, I've just reamed some holes and dow pined the plates together, no point in spending an hour tapping all the holes for threads when im not going to use it for anything serious.
    Ill be making a video in the next few days on it spinning and release the price on the 1/8 scale minis, but for now i need to get back to machining the real 671 :).
    One thing to note, Our finished machined 671 will be slightly different from this case. On the real 671 the ears you see on the casting photos will be machined 100% around the bearing plate and the top deck will be flush with the back side of the ears.
    Rear plate is reamed and dow but you can't see it
    Dropped the rotors in
    Dowed the front plate, gears slid right down
    Front cover pinned
  25. Dzuari
    Dzuari
    from Muncie, IN
    Finished the video on the half scale, also released the price on the 1/4 scale, i had to make it a bit bigger for strength and to fit some bearings, idk if your going to like the price though :/. also i take you on a walk-through of two of our builds showing some various processes and show a building that we will soon be installing a full production powder coat system in.
    <iframe width="560" height="315" src="http://www.youtube.com/embed/4PD0NNck30M" frameborder="0" allowfullscreen></iframe>
    Im working on a video now of how a 3D print works, the software electronics and hardware behind it, im hoping to have it uploaded by today and tomorrow at the latest. All the parts for the printer i will be building are done printing and ready to go, im going to start ***embling it this weekend and will any luck hopefully have it running by monday.
    Im going to print out an 1/8th scale now and it should be done by tomorrow and i will make a video of it ***embled. It is a 24hour print time on them also, so if you purchase one, more than likely you will have to wait a bit.
  26. davidbistolas
    davidbistolas
    Garen, what 3D printer are you using? Makerbot?? - I've been wanting something like that for a while ... looks awesome. Nice work, keep it up!
  27. Dzuari
    Dzuari
    from Muncie, IN
    The one im building is called a RepRap, there is links in the video's description to various websites about it and where i bought mine.
    The Prusa Mendel is the one i am building.
  28. Could you give the dimensions of the desktop model, what actually comes with it ( bearings, etc ) , final price and time frame for shp'g when time allows. thanx
  29. Dzuari
    Dzuari
    from Muncie, IN
    here is the kit that i bought, it has its part list, haven't had a problem putting it together so far.
    http://www.a2aprinter.com/index.php?route=product/product&path=20&product_id=42
    here is the video tutorials im watching to put it together
    http://reprap.org/wiki/Prusa_Build_Manual
    and here is the parts list according to the reprap website
    http://reprap.org/wiki/Prusa_Mendel
    I purchased mine for around $550 after shipping, it was shipped out of cananda the next day and i had the kit within a week.
    One thing to note though is you have to have the 3D printed pieces too, so if you dont have access to a 3D printer you will have to purchase these too.
    Here is a link that has a list of websites that sell RepRap kits and parts
    http://reprap.org/wiki/Mendel_Buyers_Guide
  30. Dzuari
    Dzuari
    from Muncie, IN
    Making the 3D printer
