What's it called?
Discussion in 'The Hokey Ass Message Board' started by dagizmoguy, Dec 29, 2011.
  1. dagizmoguy
    dagizmoguy
    from Seattle
    For my 47 Dodge what's that reinforcement piece called that runs the width of the car between the bumper and the body? In other words when I look down between the body of the car and the bumper all I see is the bumper brackets and the ground. There's supposed to be an insert there. The guy I got the car from took em out and got rid of em. Clearly he hears a different drummer than me. He also cut the drip rails off...........sigh.
    Thanks!
  2. ImaHero
    ImaHero
    from Canberra
    bar reinforcement? or Reo for short?
  3. wetatt4u
    wetatt4u
    Rock gaurds,
    valance,
    or splash gaurd,
    and I'm sure their are others names for it..
    Good luck,
    Nice ride
  4. Dynaflash_8
    Dynaflash_8
    from Auburn WA
  5. the valence? You are talking about the piece of sheet metal that filles the space between the nody and the bumper right? I have heard a different name for it but valence is the only name I can come up with.
  6. terryble
    terryble
    from canada
    gravel guard? and not all mopars had them some models were open.
  7. plym_46
    plym_46
    from central NY
    Is that a canadian built car??? The Dodge in Canada was a Plymouth body with Dodge trim. American Dodges were longer and the front fenders flaired into the doors.
    Also the rear fenders aren't correct for a 46-48.
    What length is the engine block at the head??
    Gravel shield or splash pan, or bumper valance. They were two piece from the factory riveted in the middle. Nothing fancy you should be able to fab one out of sheet metal.
    cut a chunk out of a s**** hood or trunk lid.
  8. Pop-Rodder
    Pop-Rodder
    Isn't that called the floor?...lol
  9. LAROKE
    LAROKE
    Splash apron is another name for it.
  10. sololobo
    sololobo
    What a cool Dodge, I had a 48 years ago and never see Dodges. I think the pieces would be called splash pans or gravel guards. Should be able to find some on a Plymouth sedan as there seems to be way more of them than Dodges. Good luck man, way cool car! ~sololobo~
  11. dagizmoguy
    dagizmoguy
    from Seattle
    Thanks!
    Yeah I am going to have to make some. No it's not Canadian and you're right about the rear bumper not being the original, it says "Fluid Drive" but the car's a regular 3 speed
  12. Hdonlybob
    Hdonlybob
    Wow, great looking car....that belongs right on the top when the moredoor guru's get there dander all up about moredoor's not being cool.
    That car rocks man!! I really like it, and sorry, but I like it without those sheet metal inserts between the bumpers and body..
    Hey all the early cars were that way!!
    Good luck, and build it the way you want it...and ENJOY,
    Cheers!!!
  13. George
    George
    For some reason "bumper filler" comes to mind....
  14. plym_46
    plym_46
    from central NY
    Rear fenders on the stock cars did no have a fully exposed wheel tire at the rear. and the front sheet metal is definately Plymouth not America Dodge
    Plymouth 46-early 49
    46-eaaely 49 Dodge, note the front fender line and rear fender cut out. Also Dodges had a clam shell hood that opened from the side, Plymouth standard hood opening from the front. Plymouth Wheel base 117 Dodge 119.
  15. Rusty O'Toole
    Rusty O'Toole
    Official name from the Chrysler parts list is Stone Deflector. It is made of stamped sheet metal. There is also a rubber Stone Deflector Seal and Stone Deflector Anti Squeal.
    Took a little time to find because they are in Group 13 (Frame) and I looked first in Group 23 (Body).
  16. dagizmoguy
    dagizmoguy
    from Seattle
    This newbie thanks you all for the great info! I grew up in L.A. in the 50's and I've always wanted a traditional bomb. Skirts, visor, spotlights yeah.. So this car is is gonna be that for me. Here's some more pictures if I can get them all up here.[​IMG][​IMG][​IMG][​IMG][​IMG]
  17. plym_46
    plym_46
    from central NY
    Well that is deffinately a Plymouth dash board, and those are definalty Plymouth tail lights, but that is a Dodge Grille. Me thinks you have a Canadian Dodge that lost its way and got south of the border somewhere a long the way.
  18. pimpin paint
    pimpin paint
    from so cal
    Hey,
    To build one of these rock deflector panels check out "Hammerforming'' & "Hammer forms" in the tech archives as well as the on-line metalshaping-metalshapers.org etc.
    A couple pieces of plywood or MDF, a jig saw, some gee clamps, a router & some sheetmetal will yield jus what you'll need to build those panels.
    A very easy beginner metalshaping project!
    You go now! chop! chop!
    " Humpty Dumpty was pushed "
  19. dagizmoguy
    dagizmoguy
    from Seattle
    So I got a Canadian Plodge?
    This thing gets curiouser for me every minute....
  20. mgtstumpy
    mgtstumpy
    Gravel shield, gravel tray stone tray? This is my NOS '46 Olds one. Old one was full of fatigue cracks, poorly repaired and bent pretty bad. Will keep it as a spare. This saved me time, effort and money. I was going to hammer form one using the old one as a template but this came up. :)
  21. plym_46
    plym_46
    from central NY
    measure the engine lenght Canadian cars used 25 inch motors.
  22. T Fritz
    T Fritz
    Also called a rear apron by some.
    Fritz
  23. flathead okie
    flathead okie
    plodge huh,..............yer funny
  24. Copper Top
    Copper Top
    You have a 1948 Dodge D25 with Dodge D24 bumpers and that could be the reason why the gravel guards are removed as the bumpers are different shape. Parts from a Plymouth P15 will fit your car. The probable reason the grille is painted is that it is made of pot metal and most of them are pitted. Do you know about the P15-D24 website?
  25. patrick66
    patrick66
    I've heard that part called all of the above, along with "bumper filler panel"...so, take your pick!
  26. need louvers ?
    need louvers ?
    YEP! If I had seen this yesterday instead of now I would have run you through the same 20 question deal '46 Plymouth did! I absolutely covet those rear fenders, I have been wanting a pair like that for mine for about twenty years now... We just don't find them very commonly down here in the southwest. As far as your aprons go, hammer form is going to be your best bet. Take your time and use 18 gauge if you can.
  27. George
    George
    Often used for Dodge badged Plyms.
  28. plym_46
    plym_46
    from central NY
    I think the rear fenders may be from a 42 as they had the full cutouts with no speed lines.
  29. need louvers ?
    need louvers ?
    Ya, I think your right. But I wouldn't put it past Canada to have gotten the "old stuff" to use up for their production. Just saying those high arched fenders are thin on the ground! And I found out the hard way that '42 Dodge doesn't fit a '48 Plymouth like I thought it might... Hauled those damn things all summer long all over Washington state after picking them up in Idaho, then back yo Phoenix! If anybody needs a pair, let me know.
  30. dagizmoguy
    dagizmoguy
    from Seattle
    Wow! Just from askin a question about the name of something I've got so much information here....like uh what the hell kind of car I'm driving. Thanks guys for all your friendliness and generosity!
