Ford 223 problems. Help!!!
Discussion in 'The Hokey Ass Message Board' started by SamCrow, Jan 2, 2012.
  1. SamCrow
    SamCrow
    I have a 59 F100. 223 I6 with the load-o-matic distributor. I have the timing set to specification. 4° BTDC. At idle with the vacuum advance line disconnected. The problem is when I go to plug the vac line in the advance kicks in right away. I have replaced the distributor and it still does it. I'm thinking its a carb issue. But I could be wrong. The carb is a Holley glass bowl. 1904 or 1908 I don't really know which. Any suggestions would be great!
  2. ray-jay
    ray-jay
    from Buford GA
  3. RMR&C
    RMR&C
    from NW Montana
    Do you have the advance hooked up to venturi vacuum or manifold vacuum? There is a vacuum port on the side of the carb where it should thread in.
  4. SamCrow
    SamCrow
    It is connected to the port on the carb
  5. SamCrow
    SamCrow
    Might I also add that when I attempted to drive it. It wouldn't accelerate whatsoever. Once I engaged the clutch it just bogged and died.
  6. ray-jay
    ray-jay
    from Buford GA
    How about some background on your truck. Is this a new build or has it been running good in the past ?
  7. SamCrow
    SamCrow
    it was running good in the past, except for leaking oil everywhere. It blew the rear main seal. So i replaced it and most every gasket in the motor. its got a new starter, distributor, fresh gaskets and fluids. The gas does have sta-bil in it because it sat for a few months.
  8. 510madmav
    510madmav
    I'll be willing to bet it's the pcv . Go through the pcv
    System. I had very similar problems when I first got my truck. Same truck same motor
  9. Daddyo's garage
    Daddyo's garage
    It's that glass bowl carb! You should just send it to me. LOL!
  10. johnboy13
    johnboy13
    That engine has a downdraft tube not a pcv, doesn't it? Sounds like you're pulling vacuum from the wrong spot, but if I recall, the vacuum line is a hard line from the carb to the dizzy. I could be wrong. Try plugging the vacuum line and see if it will at least drive. Keep us posted.
