Flatheads....... lets see 'em!
Discussion in 'The Hokey Ass Message Board' started by sonoramic, May 14, 2009.
  1. roseville carl
    roseville carl
    39Truck.... sounds and looks *****in!!!!
  2. fab32
    fab32
    If this thread doesn't make your mouth water I seriously doubt your claim of being a hot rodder. I'm sure there are more out there so keep posting flathead owners/fans.
    Frank
  3. 70elim
    70elim
    from PA
    Here's mine, original engine, hot rodded to a full house 276 in 1953, rebuilt in 2010. Now is 281 cubes, bored .145. 4 inch stroke, Isky springs, Manley valves, johnson lifters, Egge pistons, Potvin super 3/4, Edelbrock Heads and intake, Speedway and Melling pumps. Sounds good.
  4. ronnieroadster
    ronnieroadster
  5. 29tudor
    29tudor
    V12 out of a zephyr side job I Painted
  6. 39Truck
    39Truck
    from Sweden
    Thank you roseville carl :)
  7. 39Truck
    39Truck
    from Sweden
    Looks and sounds nice :)
    Can i ask how high ignition you can drive with on your supercharged flathead engine ?
  8. fenderless
    fenderless
    from Norway
    Nice thread:)!
    Two of mine.....
    Taildragger&fenderless
  9. MrModelT
    MrModelT
    Here is my '53 8BA with my Grandpa's old intake setup:
    the same intake on his '29 A-bone in 1951:
    ...and my reliable ol' T motor :D
  10. 39Truck
    39Truck
    from Sweden
    I like the carburator cut MrmodelT ,very nice :)
  11. MrModelT
    MrModelT
    Thanks! :D ..yeah, that was Grandpa's handy work. I am in the process (a**** other projects :rolleyes: ) of building a duplicate of his A-bone and when I have these carbs rebuilt for the project.....the cut off tops will stay for sure ;)
  12. jan bogert
    jan bogert
    my av8 '31 coupe.:)
  13. Tank
    Tank
    Heres a few of my V8s. The ones that presently run that is......
    The one with milled and chromed heads is a Merc engine, Isky Cam, Edelbrock 452 intake and Rochester 4G carb. Very strong running engine!
    The one in my coupe is a '46 59L with an unknown cam. Presently otherwise stock, but reliable as hell!
  14. fordcpe
    fordcpe
    Here is my C8BA hooked up to a c4 automatic with speedwaymotors adapter engine is 4" merc crank with 3 3/8 pistons. Edmunds heads 4 barrel holley 390 cfm carb.Runs great drive it everywere. Darrell
  15. roseville carl
    roseville carl
    Hey Kjell we need to see more pics of your AV8.........
  16. Berky
    Berky
    Does this still count as a flathead?
  17. Berky
    Berky
    Or this one? God my friend has too much money.
  18. roseville carl
    roseville carl
    Uh No ............
  19. D_Lazaris
    D_Lazaris
    from So. Cal
    x2.
  20. Jimmy2car
    Jimmy2car
    from No. Cal
    Here's mine. 290 cubic inch, Potvin eliminator cam, Austin intake, etc.
  21. fenderless
    fenderless
    from Norway
    Thanks Carl:)
    Here ya go,
    Pictures taken some years ago...
    Now she sit on 4 brand new 16" black solids with blackwalls, so much better. Didn't like the old rims and tires.
    Br
    Kjell
  22. roseville carl
    roseville carl
    Very very nice Kjell
  23. walter
    walter
    8ba, .30 over, 4" Merc, Isky 400, Offy Heads and Intake, lot's of machine work
      491 KB
      491.6 KB
      495.5 KB
  24. fenderless
    fenderless
    from Norway
    Thanks Carl:)
    Here is a video of it;
    http://www.youtube.com/watch?v=geCTPCM1CAs
    It's a 276 cid, with a 400 jr. cam, fully ported with a partiallly relive.
    Left a small edge toward the piston. Just wanted to try out something else:)!
    Br
    Kjell
  25. roseville carl
    roseville carl
    sounds great Kjell............
  26. aafc1
    aafc1
    Here's mine in my 51 F1. It's ported relieved 20 over 3/4 motor city cam merc crank.
  27. Normbc9
    Normbc9
    Here are some. The first is a 256 '53 Merc converted with a ARDUN OHV conversion kit. The Hudson's are all 308 Twin Hornet sixes.
    Normbc9
  28. Bad Daddy
    Bad Daddy
    Here are a few. .
  29. bobo1
    bobo1
    from France
    my french Flatheads
  30. flat34pu
    flat34pu
    here's mine a driver underconstruction.
    rich
      437.5 KB
