Aussie Icon-- The UTE
Discussion in 'The Hokey Ass Message Board' started by oz40, Mar 3, 2009.
  1. I think I should have looked a little closer, it is a Desoto......:eek:
  2. Thanks to you too.
    Next time you see it come up and say G'day
  3. olskl_dave
    olskl_dave
    Correct ,one suburb over, he's in Resavoir .......Chev ute, '34 sedan, and a '32 roadster....
    Regards Dave
  4. mercurymitch
    mercurymitch
    from Australia
    This is my Mercury ute pic taken while in Launceston Museum
    Okie Pete likes this.
  5. mercurymitch
    mercurymitch
    from Australia
    A Launceston ute
  6. ehdubya
    ehdubya
    Mitch, I'm amazed to see your Merc with all it's up market t*******s has but one wiper. Thanks for the pics.
  7. mercurymitch
    mercurymitch
    from Australia
    From what i understand Ford factory supplied commercials with one wiper one arm rest and one sun visor,you had to pay extra for the others
  8. RobC
    RobC
    from Australia
    Couple more for the mix.
    1936 Bedford, obviously suffering a slow death
    MkII Zephyr
  9. Aussie 40 deluxe ute i 'DUG' up just after new years, pulled the rear end and x member from it for my tudor and put the front and rear crossmembers and springs away for future use then put the body in the front yard of my mates mothers house... needless to say they got a supprise when they came back from holidays!!
    Took most of the day to get the ute out of here.. been there since '68 and the farmer told us the whole history.
    Even came with a added minor tree complacation
    Okie Pete and jd34delivery like this.
  10. RobC
    RobC
    from Australia
    Nice find, that little bit of belt line trim behind the door is gold, very hard to find as an original item.
  11. Thats handy to know! i also have the bonnet with all the trims and badges too
  12. Dago 88
    Dago 88
    Nice find. Cosidering the rarety of these utes, that almost looks saveable to me.:cool: How bad is rest of it?
  13. BLUDICE
    BLUDICE
    What makes a UTE an UTE, and not just another pick-up? AND why didn't they build them here too? Some models good pretty cool, other are ugly as s*#@.
  14. I would say its saveable, although i say that as a panel beater who restores / hotrods vehicles for a living.
    Here is a snap of the worst of the rot, and the obvious lowers behind the doors
  15. George
    George
    No seperate bed, Ford Ranchero was the 1st US version of the Ute, then the El Camino. No actual Coupe Utes here.
  16. RobC
    RobC
    from Australia
    In reality it was not just the "no seperate bed", it was that AND p***enger car comfort. This is the main reason those US built 1930 Model A specials can't be claimed as the first utes.
    The whole point was to have a vehicle you could lug stuff around with but still drive around with the wife in comfort. Slice a coupe ute through the body right behind the doors and seat and everything forward of that point is 4 door sedan or close to it.
    Cheers,
    Rob
  17. RobC
    RobC
    from Australia
    Bonnet and doors are the same as a sedan though with the exception of the '41.
    That's definitely a salvageable vehicle, I'll have to scan and post the pics of my roadster ute as found.
    Cheers,
    Rob
  18. ehdubya
    ehdubya
    Rob if you sliced my Plymouth through the front of the bed opening everything forward of that point is exactly a coupe, that's why I didn't buy a Ford :eek:
    'Station Utility' was a popular body style in oz well before the A, there were T roadster utes here too, most likely local bodies and I wouldn't be surprised if they were marketed as station utilities.
    There's plenty of trucks that got ute bodies and were marketed as utilities so ultimately it is just "no seperate bed".
  19. Bullet Nose
    Bullet Nose
    From another thread .....
  20. That Pop ute is so f*cking cool!!
  21. Boeing Bomber
    Boeing Bomber
    I love these things. The only way I'd ever get one was to make a model of one. Took a '40 Ford delivery, whacked off the top, and graphed on a roof from a coupe. Even changed it to right hand drive.
  22. Boeing Bomber
    Boeing Bomber
    I see this one at Speedweek all the time.
  23. 38Chevy454
    38Chevy454
    That is owned by the guy that does the Bonneville calendars. A friend of mine, his name is Tony Huntimer. I think the website for his calendars is www.huntimer-photography.com.
  24. RobC
    RobC
    from Australia
    There were plenty of variants globally. In Argentina you could buy coupes with a pickup bed grafted into the boot (trunk) opening at least up until 1948 and I know these were also available at least in Model A form in the US.
    The coupe ute as invented by Lou though was as mentioned previously, comfort and carrying capacity. We also had the ute (and roadster ute) type trucks too but they weren't exactly a p***enger car derivative.
    Cheers,
    Rob
  25. ehdubya
    ehdubya
    I thought I dispelled that myth earlier in the thread :eek:
  26. Ed Zackley
    Ed Zackley
    from Hokeyhomey
    El Camino and Ranchero. The two utes. As it were. Utes are cool.
  27. Here is a 35 36??? is Willys UTE I chopped the roof on and extended the doors, The roof from standard had a rake, so under instruction i took 2" out the Back and 1" up front then extended and filled the roof
    Aaron MS
    See the difference between the stock window surround to the reshaped and extended door
    door file finished
  28. B.A.KING
    B.A.KING
    i have to admit, the lines are much better.good work!!!
  29. Yes most definately! we opted to extend and de rake because of the size of the rear of the roof, the pillar just looked too big for the little ute, the rear window was completely re worked and made slightly wider with a sharper radius on the curve into the window.
    I did this job 2.5 years ago before i left the shop it is at, it hasnt been touched since which is unfortunate.
    Aaron MS
