Shop Press Tooling
Discussion in 'The Hokey Ass Message Board' started by lawman, Jan 3, 2012.
  1. lawman
    lawman
  2. lawman
    lawman
  3. Pensive Scribe
    Pensive Scribe
    I'm making this to repair a vintage tailgate.
  4. lawman
    lawman
    Very nice !!!!!
  5. MikesIron
    MikesIron
    from Union, OR
    Wow -- you've got some time into this!!!
  6. Chaz
    Chaz
    Great Thread! I'm learning a lot here.
  7. Iceberg460
    Iceberg460
    ^^x2^^
    Subscribed
  8. Pensive Scribe
    Pensive Scribe
    Thank you.
    About 7-8 hours so far. But time flies when your havin fun.
    I'll post the results here when it is cleaned up and tested.
    Doug.
  9. neilswheels
    neilswheels
    from England
    Thanks budd, usefull info for next time. I'll go and find out what 'die springs/cushions' are:)
  10. lawman
    lawman
    OK, How about anyone ever rework or change their shop press frame to handle more tonage? I had a 10 ton press years ago ans sold it in 1988.
    Just bought a Harbor Fright 20 ton. Have already started to change it to become a 45 ton air over hyd.Will cut slots in the the side posts to be able to push drive shafts and tractor radius rods thtu for straighting. Have added steel caster wheels and some bracing. What have you Guys and Gals changed on your press? As alway pictures always help. Thanks again to all for your time and talent
  11. MikesIron
    MikesIron
    from Union, OR
    And, it looks like you're working w/ a manually controlled mill, not a CNC machine -- right? If so, that makes it even cooler!!!
  12. lakester47
    lakester47
    Great thread. Subscribed. lawman, how about pics of your upgraded press????
  13. lawman
    lawman
    Should be posting some pic's later this week.
  14. Pensive Scribe
    Pensive Scribe
    Correct. I'm practicing my hand eye coordination. I figure if a machine can do it I can too.
    Doug.
  15. leon renaud
    leon renaud
    from N.E. Ct.
    For body sheetmetal you can make dies that will punch out just a few pieces from bondo! I saw the ford script logo punched into sheetmetal half a dozen times using bondo with a 1/4 inch metal plate backer.The guy spread a layer of bondo about a 1/2 inch thick over both sides of the script and set a piece of plate on top before the bondo hardened he did this on the inside and outside of the piece of ford panel so he had positive and negative profiles of the script, after that the drilled both plates so he could put alignment pins in the ends outside of the area covered by the sheet metal he wanted to punch,He then put the sandwich of dies and sheetmetal into a press he made using a hand pumped bottle jack and embossed the logo into the new panels I'm told you can do it with concrete dies also!Your not going to do production runs with these dies but if you only want a couple small parts its worth a try!you can carve or machine some from MDF or oak also again good for only a few pieces.I've thought about trying it with Coriander (sp?) counter top material it's some real tough stuff!
  16. yetiskustoms
    yetiskustoms
    Inspirinv thread
  17. WOW, that firewall is just amazing, you are the man.
  18. lawman
    lawman
  19. MikesIron
    MikesIron
    from Union, OR
    sweet -- I'm primarily a blacksmith, so can relate to the red-font tag line you've got there!!!
  20. lawman
    lawman
  21. Pensive Scribe
    Pensive Scribe
    Applies to sheetmetal shaping too.
    Doug.
    Just in case I change my signature again, for those coming to this thread later on.
    Hitting it with a hammer is easy. Hitting it in the right spot is hard.
  22. Wow, Elpolacko that is some awesome and inspiring stuff, nice.
    I need a bigger press now :)
  23. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Great thread Tom....keep it coming guys!!!
  24. lawman
    lawman
    Thanks Bob.Wish we could see some pictures of small Jig's and fixtures
    used in press work also. Maybe some home made press plates.
  25. lawman
    lawman
  26. T Hudson
    T Hudson
    Great thread, But 10 of these is a little annoying when hoping to see something new.
  27. lawman
    lawman
    So sorry "T", I won't "Bump again". Let's let this thread die.
  28. ELpolacko
    ELpolacko
    Thread won't die if it gets contributed to, but endlessly bumping it is a bit droll.
    Ask questions or try and do some of these pressings on your own and report back. Make the thread work for it's celebrity.
  29. K13
    K13
    Don't stop bumping because one guy has a snit. Interesting thread that has had more added after you have bumped it before. I always love guys that complain about a threads content but have nothing useful to add themselves.
  30. rockable
    rockable
    This is the reason that the HAMB needs to be organized in sections like Shop Tools, Metalwork, Painting, etc. it's too hard to keep up with and find threads you are interested in. Yeah, I know about "subscribed".
