Projects 1936 Chevy truck build thread
Discussion in 'The Hokey Ass Message Board' started by skippycraig, Dec 26, 2011.
  1. skippycraig
    skippycraig
    from Washington
    Tonight I made my steering column, I had an old shaft from a 54 chevy car that had both a keyway and splines so I can use the stock 36 wheel or a later chevy wheel. I found a set of new bearings for a Pepsi handtruck that were 3/4 id and fit perfectly inside 1 1/2 pipe I picked up at the s****yard on the way home for 6 bucks. Now all I have to do is carefully grind two flat spots on the steering box end of the shaft to take DD joint.
  2. Bikertrash
    Bikertrash
    from Boise
    36 chevrolet trucks are awesome! I built one and loved it. I started with nothing but a cab. shortened a 50's truck bed. Matt Whitlock from Wrecked Metals built the frame and did the chop. I wished that I wouldn't have sold it but it went to a very good home in California. I was happy to see it go to someone who took good care of it. Here's some pics of mine. Keep going on yours. I'm excited to see how it turns out. I can't seem to get more images to upload :(
  3. skippycraig
    skippycraig
    from Washington
    That little pickup looks like a blast, you must of had to squint to see out that little slit for a windshield.
  4. Bikertrash
    Bikertrash
    from Boise
    That chop was awesome. I miss it so much I'm selling my current project to buy another "choppable" car. Once you've had one, you just can't go back. My young said would say that it looked like it was "growling" at him.
  5. I love these trucks.
    looking nice !
    I'll be watching this build.
  6. jfrolka
    jfrolka
    hahahaha thats woolly's!! he just put a blower on it!
  7. skippycraig
    skippycraig
    from Washington
    Is that a 36 cabover? Thats the coolest thing ive ever seen!
  8. Midwest Rodder
    Midwest Rodder
  9. CORPO
    CORPO
    Awesome truck man, I love the 36 cabs, been working on mine for 3 years... I have never posted here (I have lurked here for a long time) but I thought I could give you a tip that I wish someone had told me when I started on my 36.. you can find the metal door columns and dash structure from a 37 cab to replace the wood in yours, and from what I was told its a straight bolt in. I see them sometimes on ebay for like 100 bucks, would have saved me a lot of headache. I built some pretty stout door columns and then had problems fitting my dash back in (ended up having to add to the depth to the dash to bump it out around the new door columns) I will also have to modify all my trim to fit back on...
    good luck on your build I will be watching
    as a side note: Bikertrashes truck was a 37, you can tell from the body line on the cowl... the 36 body line continues all the way across the cowl where the 37 cabs bodyline stops short due to how the fenders crossed the cowl.. I didnt realize this and bought some patches before knowing it
  10. It's a '39 GMC COE.
    On backburner at the moment due to customer work.
    But I may push it back in tomorrow night.
    Didn't mean to jack your thread.
    I love how your truck is shaping up !
  11. skippycraig
    skippycraig
    from Washington
    That's great advice about the a pilars and dash, the cab is next after I finish the frame. Any advice helps thanks, Craig
  12. I like the start you have, should turn ot great. I had a full fendered '36 when I was in high school. It was more of a drag or g***er style truck, 302cid chevy stroker with a tunel ram, th400, 12bolt rear, tube rear bumper. It was orange with black flames. What a fun time we had.
  13. Jalopyrama Mike
    Jalopyrama Mike
    Craig, your lowcab is looking good. I have a '36 Carryall Suburban. Been working on it for a few years. Yep, the doors can be tricky. I sandwiched the wood with metal backing so the bolts are secured into a metal backing with nuts tacked on. Running a 8in. w/87 vette tuneport & 700r4, Fatman front susp and posies springs in back.
    Truck is at Bad Donkee in Pa. and Junior (fatabone) is doing a great job, hope to have it on the street this spring. there;s a guy who goes to L'ville nsra nats who specializes in 33-36 Chevy stuff and Bowtie Reproductions in Ohio makes very nice replacement parts/fenders. PM me and I'll find the info on these two companys if you need it. Good Luck, Jalopyrama Mike
    P.S. I have a hard time posting pics but I can email some to you OR maybe fatabone can post some for me.
  14. mink
    mink
    from CT
    Thats funny i got the same exact seat from the boneyard for the same price; but it felt weird in my 32 chevy so i got a free 70's bench seat and shortened it to 47 inches.
  15. skippycraig
    skippycraig
    from Washington
    My tailgate showed up last night, 1939 chevy tailgates had a really cool script and fit stock 36 box. I was going to make one out of my original 36 tailgate and graft in the script from a later gate but everyone I found looked like a taco. It can use some cleanup around the welds but was only about 50 bucks more than a good original that needed lots of work if you can even find one.
      20.2 KB
  16. rusty1
    rusty1
    ...nice project, looks really good slammed with the fenders. Those lowcabs are a nice lookin truck.
  17. Crusty Chevy
    Crusty Chevy
    Love the truck and cannot wait to see where it goes.-Crusty
  18. Stovebolter2
    Stovebolter2
    I really dig the 36 low cabs. How the heck did you get it that low...Lols. My 36 barely has 1/2" of clearance between tire and bottom of front fender. Going to enjoy watching your build!
    David
  19. skippycraig
    skippycraig
    from Washington
    Today I finished the trans crossmember, all parts and pieces from welderseries. The center section drops out and the tabs bolt thru the frame rail.
  20. skippycraig
    skippycraig
    from Washington
    You're right the space up inside the fenders does limit how low I can go. Ended up running a 15x5 54 chev car wheel and 165r15 tire on the front and still only 3/4 inch before the tire scrubs little. The picture is with 54 wheels and L78 bias, just too big but looked cool.
      491.4 KB
  21. Stovebolter2
    Stovebolter2
    Well keep chugging along! If your like me and stop for a breather, one year will turn into two, then someone will talk you into a full resto of 65 Camino, then remodel kitchen please, and before you know it four years three years have p***ed. Worst part, I'm just a little ADD, so now darn if I haven't changed the entire direction I want to go. Rattssss!! Looks great!
    David
  22. TFoch
    TFoch
    It's going to be a great looking truck! I'll be keeping track of your progress. I like the looks of the mid 30's Chevy trucks and cars. Good luck with the project. Tom
  23. pukejohnson
    pukejohnson
    from BREMERTON
    Nice gate cuzin.
  24. mitch 36
    mitch 36
    Skippy, your truck looks real good. i have had mine since 1979 and its on its second rebuild. I have replaced the wood twice now and if i had to do it over again I would have welded steel in its place. Hopefully by spring I will have mine back on the road. Mitch.
  25. skippycraig
    skippycraig
    from Washington
    Sometimes you have to go backwards to go forward I guess. Getting ready to finish all the welds, notches, sandblast, and paint the frame. Can't wait to start bolting everything on for the last time. I found a generator just to be traditional, don't know If I should mount it high or low on the motor.
  26. Mount it high, you'll be wanting to show that off ! :D
  27. skippycraig
    skippycraig
    from Washington
    Notches are almost done. Look what came in the mail today, guess I'm one of you guys now.
      28.1 KB
  28. skippycraig
    skippycraig
    from Washington
    Welding, grinding, wire brush, and finally paint tonight. Ready to start bolting frame together for the last time hopefully.
  29. Damn! You aren't messing around are you? Cold kickin' it!
  30. Scotts Enterprises
    Scotts Enterprises
