History 64/65 Comets old drag cars lets see pictures
Discussion in 'Traditional Hot Rods' started by apound, Feb 17, 2009.
  1. AFX DAVE
    AFX DAVE
    Ryan:
    I think your into 65 Comets. Is your 65 Hipo a original Hipo Comet? I only know of a Half Dozen or so out there that are street able. That's why I am asking. Originals are Rare to find in today market.
    Factory 65 AFX Comets, all Six are accounted for! Some are Original but in there last 66/7 Match Racing Style w/original drivers paint job, Some are over restored, others are Rebodyed but all have the original Paint Lettering.
    Factory 65 BFX Comets, I think only Nine are known to be around! There is still some out there to find!! There out there some ware like the street able 65 Comet Hipo Cars. Good Luck. ~~~~~~~~AFX DAVE~~~~~~~~
  2. teddisnoke
    teddisnoke
    from So Cal
    Okay, so you know how once you get a thought on something, you cannot get it off your mind?? Here's what I'm envisioning:
    I can fabricate an adjustable front mount, for the front heim, off the frame connectors. Adjustable, at least three mounting holes. The rear mounts will be attached to the four u-bolts, with tabs welded on to mount the back helim. Both heims are rotationally adjustable, with the front length adjustable. BY setting multiple mounting holes in the front mount, I can "tailor" the fit so that the bar will follow the spring arc somewhat, making it pre-load, or soft, to hit hard, or not... Remove two mounting bolts, and the bars come off for the street use.. Okay, start shooting up my idea.......;)
  3. 296 V8
    296 V8
    from Nor~Cal
    Great idea … I will use it if you don’t mind.
    Question
    The center tube that has the spring pad looks to narrow for the U bolts to land on.
  4. MD1320guy
    MD1320guy
    296 V8
    I only used a 2" wide leaf spring so it would fit inside brackets welded to the sides of my 2" frame rails. Therefore I only had to make the saddles 3.25" wide for the U-bolts to fit. I found 4x4 3.5" U-bolts that were 9/16" dia. If your springs are wider (2.25" - 3.00") just add 1.25" - 1.50" for the U-bolts to the spring width. You are more than welcome to use the idea. It wasn't mine. I picked it up back in the late 60's running Super Stockers.
    Mike
  5. C5GY63EHP
    C5GY63EHP
    from NJ
    Here are some pictures of my Hipo Cyclone.....
  6. C5GY63EHP
    C5GY63EHP
    from NJ
    Some more pictures......The guy I got it back from installed the side exhaust....I just ran a set of small header mufflers....in 1994 I installed that master cylinder while I was having the original re-built and never re-installed....I have it on my to-do list...
  7. C5GY63EHP
    C5GY63EHP
    from NJ
    Here is a wheel combo that I ran for a while.....and I also ran a 8000 RPM rally pac in it for a while in place of the original 8000 rpm Rotunda Tac.....
  8. MD1320guy
    MD1320guy
    Dale
    Looks like that should work fine. Sort of a modified "Cal-Trac" style set up. I suggest you use multiple mounting holes at the rear as well. The more distance below the axle the more leverage from the traction bar.
    Mike
  9. 296 V8
    296 V8
    from Nor~Cal
    Thats one choice comet .... mine will be black one day
  10. spike427
    spike427
    from Kentucky
    I remember this car as you contacted me about wanting to buy an original tach for the car (that was ***embly line installed) and you wanted to sell it as you had gotten it for alittle nothing.I still have your info and e-mails.
  11. 64 a/fx
    64 a/fx
    on my build I wanted to get away from spring bind that I have in my 55 w/old school traction bars. went with a compe***ion engineering floating housing kit for the 9". works fine with the ladder bars and no spring bind.
    alan
  12. 65 comet
    65 comet
    from ohio
    How much movement to these have? Im putting these on mine and just wondering if im doing this right. Should there be any movement?
  13. shomanwi
    shomanwi
    Mark your car looks awesome with those wheel and tire combo. Ryan
  14. shomanwi
    shomanwi
    Hi Dave - thanks for responding to my post. I was wondering the amount of those cars because I have read that Ford made about 90 of them and from what I have found is exactly what you said that only a hand full or so of the street hipo’s and the race cars where left. Also if anyone has any info on the Tom Coward cars could you let me know. Thanks again Ryan
  15. MD1320guy
    MD1320guy
    65 comet
    The "old school' style floater like I made only allows the axle housing to rotate so the spring doesn't wind up. I believe the more modern Comp Eng set up, like 64 a/fx used, is also a slider which allows the housing to move front to rear.
    Mike
  16. TheQuietOne
    TheQuietOne
    from Goneville
    I will be attending this for sure..
    Travis
  17. Troublemaker427
    Troublemaker427
    We'll be there with two cars in the show and possibly racing two others if the logistics work out...
  18. 64 a/fx
    64 a/fx
    almost correct, the floating housing allows the spring to move rearward in bump but the housing stays in the same place held by the ladder bars. it will travel up and down, but no rearward as the spring increases in length for a bump.
    so far working great and no problems. I did add a piece of teflon to make it just a little smoother.
    alan
  19. ClearSpot
    ClearSpot
    from Michigan
  20. SLCK64
    SLCK64
    Does anyone have pics of 4 door stock cl*** Comets racing? Anyone know if there were any?
  21. mercuryjunky
    mercuryjunky
    from arvada,co
    Great shot, So this one is suppose to be the Deleorean 65 Comet?
  22. mercuryjunky
    mercuryjunky
    from arvada,co
    How about some Comet Drag Racing Action for some motivation.Awesome.Cant wait for the season, Get Those Projects Done.
    Comet TV courtesy of Steve the Sniper
    Jay Zolko driving the Tribute Dyno Don (Ugly Duck)1964 A/FX Comet wagon, doing 9000 rpm burnout and shifting at 9200 on this p***. **** Estavezs driving the Tribute Phil Bonner (Daddy Warbucks) 1965 A/FX Falcon. Great race!
  23. Analog Dog
    Analog Dog
    from Utah
    Up for auction at Me***...
  24. 65COMET
    65COMET
    Steve;which date? I went to the Florida sale site,found a nice 64 Comet and a 65 SOHC Comet that my friend built and sold,but not that red 65. ROY.
  25. porkshop
    porkshop
    from Clovis Ca
  26. 65COMET
    65COMET
    John;Thank You,somehow I missed the Comet,I went through the list of cars,found the other Comets!! ROY.
  27. b.guggenmos
    b.guggenmos
    Do you anything about this car Dave or anyone? Brian
  28. ClearSpot
    ClearSpot
    from Michigan
    Yes....George Deleorean,"the hi risers"(Mercury engineers),Wayne Gapp..
  29. choppednslammed
    choppednslammed
    The stance in this pic is BAD***. What did they do back in the day to get the fronts to sit like that? Any info would be greatly appreciated ...THANKS Jim
  30. AFX DAVE
    AFX DAVE
    Brian:
    I don't know any thing about the Me*** 65 BFX Comet, that might be the 15th Comet??? I can't tell if it is from the first Batch or the second Batch??? I need the VIN also look at it in person. ~~~~~~~~AFX DAVE~~~~~~~~
