Im getting ready to remove the mustang 2 on my Rockne coupe.Im planning on putting a drilled dropped axle.My (?) is,what front end is the better bang for the buck Superbell or Lucky 7...
I've used both, never had trouble with either one. Have never used ch***is engineering yet so can't say anything about them.
I will be the first to suggest looking for a stock 1933 to 36 Ford front axle, you can find them pretty easy stock or dropped and drilled.
Call OkieJoe, he a hambr' and that is all he does is drop axles. He will provide you with an original ford axle, drooped and drilled etc Google Joes' Speed Shop - you won't regret it.
I have a "Lucky7" on my current build and it is forged, not cast.. I had a good experience dealing with them.. I also have a Superbell(cast) on my other coupe and has been find for 2 years.....
