Customs What have you used for Peep Mirrors
Discussion in 'The Hokey Ass Message Board' started by oldpaint, Jan 13, 2012.
  1. oldpaint
    oldpaint
    I had some peep mirrors that mounted on the top of the door on my 56 chevy delivery, but they hit/rubbed on the drip rail. I would like to leave them off, but it's a delivery!
    I am looking for ideas for peep mirrors that are different or mount different. I have searched motorcycle mirrors, lots of different stuff.
    What have you used?
  2. oldpaint
    oldpaint
    PEEP...PEEP...PEEP
    I'm backing up this thread!
  3. V4F
    V4F
    from middle ca.
    i used some , but found they were not all that good . i put gl*** wings on my car with lil clamp on mirrors . excellent vision ........... steve
  4. harpo1313
    harpo1313
    from wareham,ma
    ive always taken the bracket that clips over the door off,drill a hole in the top of the door and bolt it directly on the door with the flattest head screw you can find.lock***e
  5. oldpaint
    oldpaint
    Gl*** wings? Do you have a picture, or can you explain further.
  6. V4F
    V4F
    from middle ca.
    sorry about not explaining . i have an "A" coupe . they make windwings for them . but im sure you can make them if they dont make them for your car ......... steve
    maybe you can see them here .
    [​IMG] my albums have a few pix . http://www.jalopyjournal.com/forum/album.php?u=61463
    go to my daily driver
  7. Rocky
    Rocky
    Classified Editor
    I found a pair of mirrors marked "57 IHC" at a swap meet a few years ago. I modified them to work as peep mirrors and welded a couple mount tabs at the top of each door. On the p***enger side I installed a stick-on 3" convex mirror over the original gl*** for better vision...they were a bit much but definetely different!
  8. Mike Miller
    Mike Miller
    I used a couple of mirrors off a moped. just drilled and tapped then tightened the jam nut. They both have a slight convex shape to them so I can see my rear wheels and the road behind me without much distortion.
      414.6 KB
  9. ratrodder34
    ratrodder34
    from Irvine,ky.
    That coupe is nice REALLY nice!!!!!!!!
  10. oldpaint
    oldpaint
    Hey, Thanks for the ideas. I see what you are talking about now ratrodder34, I don't think they would work on a 56.
    I'm thinking I could make a mount for my peep mirrors that would slide over the top of my vent window. I could then attach them like harpo1313 did. I might even still be able to use the vent widow if I readjust the mirror.
  11. matthew mcglothin
    matthew mcglothin
    X2!....drooling
