Retro fit an 1936 ford heater
Discussion in 'The Hokey Ass Message Board' started by LUCKY DEVIL 13, Jan 15, 2012.
  1. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Anyone out there ever retro an original heater?
  2. define retrofit
  3. F&J
    F&J
    Is it a South Wind gasoline heater?
  4. LUCKY DEVIL 13
    LUCKY DEVIL 13
    I guess I mean removing the old heater core and putting in a modern heater core
  5. LUCKY DEVIL 13
    LUCKY DEVIL 13
    No it is a HaDees Standard
  6. F&J
    F&J
    You could, if you were able to find the correct size core, which is doubtful...they are so small.
    If a rad shop did it, it would be $$$
    What is wrong with the old core? Most I have seen are still good, unless it was smashed or poked with a screwdriver.
    The fan motor can be run on 12v with a resistor, or even the old multi speed heater switch, which is a resistor. or, use a home computer fan, they are 12v DC
  7. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Someone cut the ends off the pipes
  8. F&J
    F&J
    Sounds fixable. I changed the pipes on mine, because they were not in a good place.
    ..any chance you can post a pic of the damage?
  9. john mullen
    john mullen
    Post a photo of your heater . I have serveral and may be able to help you...
  10. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Here are the pics of the pipes and they are packed with rust and **** as well
  11. F&J
    F&J
    Wow, I have never seen one with what looks like steel or iron pipes.
    The core looks promising. It does not look rotted.
    I try to fix what I can. If there was no way to swap out the pipes to copper pipe or copper tubing, I supppose I'd try some sort of descaling solution from the hardware store.
  12. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Here are a couple pics of the heater and the core
  13. F&J
    F&J
    They are using heavy duty pipes that also act as the mounts.
    Me,... I would remove those pipes from the tanks, then use copper pipe.
    Then, I would make new mounting brackets to solder to the top and bottom tanks.
    Mount a thin profile 12v computer fan behind it, and then it can tuck further forward under the dash. They stuck out a lot because the old fan motor and blade took a lot of room.
  14. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Ok cool thank you!!!!
  15. blue 49
    blue 49
    from Iowa
    I made my own heat exchanger for my Tropicaire heater out of 1/2 and 1/4 copper tubing and aluminum flashing for fins. Sorry, but I didn't take any pictures of it. Used a computer fan.
    Blue
      485.6 KB
      482.2 KB
  16. john mullen
    john mullen
    There were many heaters being made by differint co's back then none were factory installed only dealer or other garages installs. if your looking for og to your perticaler car ther wern't any .. In otherwords any one of the heaters from that era would be correct if thats what you are looking for. fix yours or Ill sell you a restored one.pm me if needed..John
  17. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Yeah I know they weren't factory I just thought since it was there maybe I would use it or I may just sell it not really sure - But thank you for your help it is greatly appreciated :)
  18. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Very cool!!! Looks like it turned out really nice!!!
  19. Aviator
    Aviator
    It is easy to retrofit and down size an old heater. NAPA has a ton of cores in all sizes and price ranges. Use computer fan from Radio Shack,etc
  20. LUCKY DEVIL 13
    LUCKY DEVIL 13
    Right on!! Thanx!!!
