How Can I Tell If I Have a True 327???
Discussion in 'The Hokey Ass Message Board' started by bmart, Jan 16, 2012.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    250 HP 327="power pack" heads, small 4 bbl (either Rochester 4GC or Carter WCFB) and exhaust manifolds with 2 inch outlets
    300 HP 327="double hump" heads (with 1.94/1.50 valves), larger 4 bbl (Carter AFB on corresponding cast iron intake manifold), and exhaust manifolds with 2.5 inch outlets
    Those specs cover '62-'65. In '66-'67, there was but one 327 in full size cars; it had double hump heads, a variety of 4 bbl carbs (AFB, AVS, Holley, or Rochester Quadrajet), and the 2 inch outlet exhaust manifolds, factory rated at 275 hp.
  2. chubbie
    chubbie
    the 283 "powerpack" had a TPEE identifier on the front of the head (same place the double humps can be found) right or wrong any engine with this identifier was called a POWERPACK head a lot of 327"s had this head
  3. Larry T
    Larry T
    It seems like most of the 327's I ever messed with had a "double hump" 461 or 462 head of some sort on it. Some of them were high performance, some of them weren't.
    Larry T
  4. 201
    201
    With all the work everybody is doing to figure out the casting numbers, I tried to go on the Mortec site, but it won't open. Must of dissapered in cyber space!!!
    Anyone have another site that decodes SBC casting numbers??
  5. Russco
    Russco
    from Central IL
    The last 3 327's I tore down all had 461 humper heads 2 were out of chevelles one out of an Impala they were all 1965 or 1966 motors. all 3 had H coded suffix's
  6. Larry T
    Larry T
    Ya just gotta know the secret handshake. :)
    http://web.archive.org/web/20080518030656/http://www.mortec.com/
  7. 201
    201
    Thanks Larry T, I edited my Mortec link. Internet Archives to the rescue again!! I go there for their live concert archives all the time. Wher else can you find 8,000 Great. Dead concerts, 500 New riders, 500 Donna the Buffalow, even Warren Zevon??? Makes my eyes red just thinking about it!!
  8. Illustrious Hector
    Illustrious Hector
    Any 305 will have the dipstick on the opposite side as a 327
  9. Gabby
    Gabby
    68 Camero could be had with a 210 H.P. 327. small 2 bbl.
  10. squirrel
    sure about that? The dipstick changed sides in 1980, didn't it? 305 was around before then.
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, the 305 came along in 1976.
  12. jimmy six
    jimmy six
    12 year old post…what every it was is now worn out.
  13. Illustrious Hector
    Illustrious Hector
    Ya got me again
