What year GM steering wheels will fit GM columns
Discussion in 'The Hokey Ass Message Board' started by chopsdeluxe51, Jan 18, 2012.
  1. chopsdeluxe51
    chopsdeluxe51
    from Steel City
    does that make sense? I'm wondering what years of GM Steering wheels will fit a late 70's GM tilt column? Anyone know?
    Chops
  2. squirrel
    How well do you want it to fit? do you want the horn to work and the turn signals to cancel?
    They changed in 69, mostly. That's when the key moved to the column (trucks in 73, vans in the late 80s) and the column got bigger diameter, and the horn contact/cancelling cam design changed drastically.
  3. As far as shaft diameter and spline count, I think all GM wheels will fit from late fifties up through 90`s.
  4. chopsdeluxe51
    chopsdeluxe51
    from Steel City
    I would like the turn signal to cancel and the horn to work still...damn. The car is a custom and I had a grant laying around and put that on and I HATE it...I want to do a nice wheel, maybe even a white or a pale yellow wheel that would look good and still have all of the functional aspects of the modern column. Anyone have an suggestions or ideas for a wheel without spending a ton of cash?
  5. eaglebeak
    eaglebeak
    Almost anything before airbags
  6. squirrel
    Depends on the flavor of the car, you might find an old Superior wheel, or a modern repop, that fits on the Grant style 3 bolt adapter.
    You should be able to make an earlier wheel fit, it could take some work to get the horn/cancelling working, but it should be possible. I've gone the other way, putting a 70s wheel on a 50s/60s column a few times, it's not real difficult. But the hub diameter probably not match real well. Although it depends what column you have.
    Also if the later wheel looks out of place, the column probably does to...you could swap in an earlier column, perhaps from the mid 60s
  7. chopsdeluxe51
    chopsdeluxe51
    from Steel City
    Good point about the column...never really considered that. I'd just like a white, solid 3 spoke wheel...problem is I can only find wheels with the holes.
  8. LongT
    LongT
    The Grant 3196 adapter fits 69-94. So those years are compatible splines anyway. Any help?
    Bill
  9. chopsdeluxe51
    chopsdeluxe51
    from Steel City
    yes, I have an adapter on it...I just need to find a nice white, or pale yellow wheel. ANybody have one? : )
  10. squirrel
    A friend recently sold one on ebay...went for over 100 bucks, I think. Superior "The 500"
  11. chopsdeluxe51
    chopsdeluxe51
    from Steel City
    I may have found a steering wheel from a 60 Biscayne...anyone know if it will bolt right up still being able to cancel the turn signals and making the horn work on a late 70's GM tilit column?
  12. xxzzy999
    xxzzy999
    You might want to contact Ididit or go to their website. They have a lot of good information and products that help match up steering wheels to different year steering columns.
    517-424-0577 www.ididit.com
    Regards,
    X
  13. Dog Dish Deluxe
    Dog Dish Deluxe
    from MO.
    I think you should be fine, The turn signal canceling cams were the samu up into the 80's. But you never know.
  14. chopsdeluxe51
    chopsdeluxe51
    from Steel City
    thanks guys...I'm just waiting on this guy to PM me back on the wheel. Any tips on restoring wheels, or anyone know of any threads? This will be my first undertaking of restoring a wheel...
