most important tool in your shop
Discussion in 'The Hokey Ass Message Board' started by pdunn10, Jan 18, 2012.
  1. milwscruffy
    milwscruffy
    Yep, the older I get the more I lean toward red cause black don't show so well for me. But your still using fancy tools ( poster board ). I thought thats what empty beer can cases were for !
  2. Cerberus
    Cerberus
    My girlfriend said it's the vice and it's only a zipper away. LOL
  3. rrayne
    rrayne
    one more thing. if you dont have a digital camera, get one. as you take stuff apart, the whole car/truck, the wiring, engine, etc.... take lots of pics. it helps to put it back together.
  4. kgp50
    kgp50
    My Essentials = 60 gal. compressor, 220 mig, 4-1/2" angle grinder, 6" bench grinder, 10" drill press, 3/8" electric drill, hack and reciprocating saws, bench & vise. That mix of tools has helped me cover a lot of project territory over the years.
  5. rob lee
    rob lee
    from omaha,ne
    Get a good vise,use them all the time!
  6. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I think the torpedo heater was priority on my list,I used a hand long board to do bodywork.I also had a used 1 hp compressor for painting ,A used spray gun,That was along time ago,But thats what I started with and a small set of companion tools.I got my mig and arc later and a bigger compressor.
  7. GaryB
    GaryB
    from Reno,nv
    how about a GOOD fire extinguiser(sp),with out one all your TOOLS will be junk, just my $.02
  8. k32t
    k32t
    from Hog town
    mig and cut off tool
  9. Lotek_Racing
    Lotek_Racing
  10. hillbilly4008
    hillbilly4008
    from Rome NY
    Things that get used in my shop on a daily basis
    -MIG w/spool gun attachment
    -horizontal bandsaw
    -Vise grips
    -BFH
    -7" Milwaukee grinder
    -4.5" angle grinder
    -Victor oxy/acetylene torch
    Things that I use almost everyday
    -variable speed 1/2 Dewalt drill
    -drill press
    -plasma cutter
    -car lift
    -cherry picker
    -bench vise
    -bigger BFH
  11. New Old Fart
    New Old Fart
    Right now its the heater !!
  12. wallygator
    wallygator
    With the basics that you have, Torch set then Mig.
  13. KWashburn
    KWashburn
    A clear head. Probably the best tool you can have...
  14. Mr48chev
    I went for a lot of years with just hand tools the usually sanders and grinders and my torch and old Forney stick welder.
    A few years ago I bought a floor mounted drill press and it gets used on almost every shop project I work on no matter what the project. The second thing that took a long time to get was a belt sander with a nine inch disk sander on it. That is another piece that gets used all the time now.
    The 220 mig that popped up on craigslist right when I had the money stashed away to buy one is nice and handy and I use it a lot but I could have gotten by with the torch and the stick welder. It will get some serious use in the next few months along with the horizontal band saw I found on Craigslist for 80.00 a few months ago and put 20.00 worth of bearings and a new blade on to make it like new.
    I have two vises set up to use at the moment. the old 4 inch Craftsman that I have had since a few weeks after I got married and a six inch that sits on one end of a beam on a stand while a bench grinder sits on the other end. Both get used all the time.
    A chain hoist and or a cherry picker engine hoist is a must have. either will save the back and often can take the place of a helper or two.
    It wasn't spendy as I got it on sale but the aluminum frame HF "racing" floor jack is handy as hell for grabbing and lifting and holding things up. It is a lot easier to grab and carry around than the 90lb 3 ton jack I have had for ever.
    A lathe would be nice but I don't have a place to put one and outside of the 13 years I taught high school autoshop I have never had access to one. Besides my buddy lives two miles away and has one of the most complete privately owned metal working shops on the planet.
    The main thing is buy what you find that you need or what you decide will help do things just a bit better or a bit easier.
  15. Air is the life blood in a bodyshop, so a big *** compressor.
    2nd, torch
    I'd really like a tig.
  16. 4 1/2" grinder with a paddle switch, and a good 240 mig welder
  17. JohnnyP.
    JohnnyP.
    my #1 tool is my coffee pot. always going at the shop. compressor with a few tools, and a decent MIG will get you pretty far. i cant go a day with out pulling out my vixen file.
  18. angle grinder with cut off wheels, grinding wheels, and wire wheels, MIG welder, a sharpie, something to make templates out of, and lots of light.
    you can do alot with a little.
  19. mgtstumpy
    mgtstumpy
    Compressor followed by air and electrical tools, sockets /spanners, panel hammers and dollies, vice grips and MIG, not in that order. Engine crane and stand and then the rotisserie. Priorities change.
  20. big bad john
    big bad john
    .......Friends....Fidge....beer...chairs.....the perfect garage
  21. bonez
    bonez
    from Slow lane
    Just Like Kevin Lee said, i built my car w/ just this, and the obvious screw drivers, spanners, sockets BFHs and such...
    A BFV (Big****inVise) is also close to mandatory. And after you discover air tools you cant do without anymore.
    A O/A torch is the next thing i will buy.
    No doubt about it.
    All other stuff, like plasma (which i have now), bench sanders, bandsaws ecc ecc...are WAY HANDY, but not strictly necessary. of course they make life lot easier.
    I would also love to have a lift, instead of crawling on dirt.
  22. clockwork31
    clockwork31
    I already had the basic tools (safety gl***es, measuring tape, soket set, screwdriver, hammer, levels, etc.) but later I bought a bench grinder, compressor and tools, 4 1/2 grinder, cut off saw, drill press, mig, sawzall, c clamps, and lately earplugs and dust mask (this should be in first...)
  23. brokenspoke
    brokenspoke
    My parts washer
  24. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Mine is as follows...
    8' flouresent lights
    jacks and jack stands
    sockets and wrenches and impact wrench and air compressor angle grinder c clamps and various other small stuff tools
    mig
    plasma cutter
    torches
    breaker bars
    specialty tools
    but gota have posters of hotties on the wall and some hotrods also...
  25. cbr74
    cbr74
    from Nampa, ID
    Not necessarily in order of importance but the tools I find the most indispensible are:
    Curtis 2 stage, 80 gallon air compressor (and the retractible 3/8" hose reel to go with it)
    Parts washer
    Blast cabinet
    Mini mill
    1/2" impact
    air chisel
    and plenty others I'm not thinking of because the coffee hasn't kicked in yet.
    I do agree with Stubbs about the lights. I scored a selection of fluorescents from CL for next to nothing. I put them up myself using a rented sheet rock hoist from Home Depot. It's amazing what good lighting does for you.
  26. oldcarfart
    oldcarfart
    My 6" vice.
    It doesn't talk, smoke or drink, always available, never late to work, no BS issues, it will never piss you off, never disappoint you and doesn't eat, drink, sh*t or piss.
  27. Paulie9fingers
    Paulie9fingers
  28. A good lift is a must have ... Laying on concrete ****s ...
  29. Royalshifter
    Royalshifter
    Moderator
    Mine would be the floor in my shop....my caveman fabrication skills ends me up there frequently and can fabricate mostly anything on it.
  30. D.R.Smith
    D.R.Smith
    I have mig,stick,lathe,plasma,drill press,chop saw,9 in disk sander,blast cabinet,press, shop crain ,air compressor,and all the hand tools I can use.But the most important tool I have is my 4 post lift.I use it every day.I can put lawn mower on it to sharpen blades without a fuss, 4 wheeler goes on it,Raise it 4 ft and you have a wielding bench or regular work bench. All the way up it makes a rack for hanging parts when paintting.If I need to load something on my truck, I raise it up to bed hight and slide it off.plus if something is on it I can raise it up and still have open space under it to work on something else. The biggest plus, is when you need a different tool after you have gotten under the car.It is so easy just to step over to the box,no up and down.As you get old you will understand.
