What part of a Hot Rod build do you find the most difficult???
Discussion in 'The Hokey Ass Message Board' started by fiftyv8, Jul 19, 2010.
  1. handmedown40limited
    handmedown40limited
    from tracy ca
  2. Cruiser
    Cruiser
    I have a lot of patience, I have finished every project car started. I like doing the wiring. I'll wire a car all up and then a friend comes by and checks everything out for me. Most of the time he finds a couple of things to correct.
    The hardest part of building a car is things you don't want to do. It's hard to get shops to do things in a timely manor and not put you off tell next week.
    When in high school building models, I was the only one of all my friends who would finish a model. Won a lot of trophies back then at the World of Wheels shows.
    CRUISER :cool:
  3. the part im at now. making it all work together. I've got the engine/trans in. rad mounted. now to wire and plumb it all. I'm pretty good with a soldering iron. but, oh boy am i feeling overwhelmed and a bit intimidated. This is my first large scale undertaking like this.
  4. rebelrat
    rebelrat
    Having to take the engine out after the first start up to fix a tiny oil leek
    when all I wanted to do was drive the **** out of it..lol
  5. The37Kid
    The37Kid
    I've desided my Roadster will never get wired in my lifetime. I'll run the conduit inside the boxed frame rails and plan out were things will go under the dash, but someone else can run the fuse. :(
  6. miraclepieco
    miraclepieco
    I drive it first, then fix that little stuff the following winter. Like right now I've got a residual pressure valve leaking, but it's not getting fixed until next off-season! Plus my speedometer doesn't work and the blah blah...
    I also try to alternate tasks that I enjoy with those I dread. Like one day I'll work on brake lines (ugh - gotta get UNDER the car and do tedious work), then the next I'll install the radiator shell or something equally rewarding that feels like I've made big progress.
  7. mgtstumpy
    mgtstumpy
    Money, time and sometimes motivation.
  8. cheepsk8
    cheepsk8
    from west ky
    Focus for sure. I have a two week rule. Once I get a car going under it's own power, I only keep it down for upgrades for two weeks max. That way I get to drive a lot more but I never seem to finish a car. I need a new rule....
  9. anyone else fall into this catagory i have trouble finding money to finish a project but i allways seem to find money to buy the next one ......... i need help
  10. grazy
    grazy
    Research:Old parts take forever to find what you need , then before using old parts if you have a question or need info you spend days finding answers . So many people give you an opinion or what they believe it to be true in a matter of fact like manner and alot of the time they are ********ters who dont know what they are talking about. Sometimes restorers know the answer sometimes older mechanics occationally older racers . We need a good vintage tech article archive with info from back in the day ! Anybody found any ?
  11. fiftyv8
    fiftyv8
    from CO & WA
    Yep, got a yard full of future projects, every new project puts the current further behind funding wise.
  12. vividlyvintage
    vividlyvintage
    For me is trim. Both taking off and putting back on. Some of it is so fragile. I always end up with atleast one piece of wavy trim due to being bent slightly.
    Thanks,
    "Skrach"
    My Vintage Blog:
    www.VividlyVintage.com
    My 55 Chrysler Worklog:
    www.Pop's55.com
  13. fiftyv8
    fiftyv8
    from CO & WA
    Right now I am struggling with getting my ebrake lever correctly ratio'd so as to having in the middle of the car bewteen the seats but with a intermediate lever system under the floor that pulls up smooth and not too heavy, just like a production car setup.
    Never have been able to get is feeling right on past projects.
  14. Frenchy32
    Frenchy32
    from arizona
    For this second project trying to find the back cab panel. So I decided I will be building the whole thing from another panel to make it look proper. And now looking for the floor braces for a model A again I will make things happen I am to impatient but I am jazz to start on this one.
    Frenchy
  15. Hdonlybob
    Hdonlybob
    Hardest part for me is finishing the little stuff after I get it running and on the road.....
    Cheers.........
  16. venturesomerite
    venturesomerite
    from CT
    I really like doing to work and problem solving, I find it hardest to find the money or compromise to stay within my means.
    I tend to be a "well, while I'm here... or I've already got this half apart..." kinda person.
  17. Paying for it. Time. Finding the right parts. Effort.
  18. fiftyv8
    fiftyv8
    from CO & WA
    I've decided the hardest part for me is hooking up my T700 tele cable to the carby and getting it to work correctly. It has cost me much time and some money and still it dont work right...
  19. TexasSpeed
    TexasSpeed
    from Texas
    The difficult part?
    My build being my first ever ground-up build so I spend a lot of time researching what it takes to do it right. That and the lack of knowledge of how to build a car but that's getting worked on throughout the course of building my A. No complains though..
  20. ironpile
    ironpile
    At 70,I agree with you on that,next is bodywork and paint prep because my indurance is kinda low.
  21. y-oh-y
    y-oh-y
    The hardest part for me is getting the picture in my head as to what I want it to look like. Once I get that picture it is fairly easy to get there, but without that picture I just go in circles. Right now I am looking at the fugly *** end of my 60 f100, I dont like the way it looks and I have no clue as to what I want to do with it.
  22. afaulk
    afaulk
    The little **** drives me crazy. You know....the parts that don't come with the screws, clips, etc. You have to wait while your re-order comes, and having to fab so much little stuff, spacers, brackets the list goes on because almost nothing fits well without modification (read extra work) OK back to work! Why does this trans mount have threads in it for a friggin metric bolt???? GO FIGGER!!!!!
  23. LowKat
    LowKat
    the last 10 percent
  24. falcongeorge
    falcongeorge
    from BC
    Just did that five minutes ago. Its about +8 C, time to get off my ***. Didnt really do much today other than go out and formulate a plan for next weekend, which is, Finish off re-wiring and improving the lighting in the shop, fix the pressure switch on the compresser, push the chevy II out, pressure wash the front clip, push it back, put it up on four axle stands, pull the front suspension/subframe, start cutting the old floor out, hammer a new swage in the replacement floor pan where it goes up to the tunnel about 2" back from the originals so I can weld the original trans crossmember mounts back in in a position where the 200R4 will fit, cut the spot welds out holding the factory trans crossmember mounts,weld the new floor in, and weld the original trans crossmember brackets in over the new swages, so the engine and 200R4 will slide in, all the while looking like chevy did it that way. I figure in actual fact, I will probably get about as far as cutting the rusty floor pan out.:eek::rolleyes: But hey, after no progress all winter, its a start.
    Oh yea, I forgot, I still havent replaced the stolen welding regulators, so I guess I wount be welding any floor pan in. But hell, I dont have a prayer of getting that far anyway, who am I kidding.
  25. big bad john
    big bad john
    .......Getting enough money to pay for it...
  26. falcongeorge
    falcongeorge
    from BC
    Without a doubt, the single most difficult part.
  27. Ironpile im 32 and i hate crawling under them.. Its my least fav. too also not gettin BURNT OUT on it.. Only sometimes this happens but i start real strong and when its down to only wiring and plumbing i stand around for a week and drink beer and look at it cause im so burnt out on building it and just keep telling myself im in the home stretch
  28. fastcar1953
    fastcar1953
    knowing when to quit and start another project.
  29. silversink
    silversink
    The fifty dollar daily parts runs
  30. Mr48chev
    Coming up with money when it is needed. With my wife in school (yes she is a 62 year old college senior) it's hard to have extra bux when the project needs them.
    I did send Dwight Bond a money order today for the adapter and goodies to hook the T-5 to my 8BA. Now all I need is something to put that combo in.
