I hauled home a real WWII Airplane
Discussion in 'The Hokey Ass Message Board' started by carlisle1926, Jan 20, 2012.
  1. carlisle1926
    carlisle1926
  2. carlisle1926
    carlisle1926
    Those tires and wheels would probably look more like aircraft tires as well due to their large size. I could use the wheel adapters to make them fit a 1 ton dually truck axle.
  3. Bobby Green
    Bobby Green
    Good for you !! nice save.
  4. tattedfordguy
    tattedfordguy
    I would stick that next my garage and build a sick *** man cave out of it...
  5. Iceberg460
    Iceberg460
    Man, words cannot describe how f*%^in cool that is. Too bad I don't live closer, would love to help out on a build like that. Hell I bet I could spend days just looking at all that cool **** you got stashed in your yard.
    Good luck with the build and keep us updated..
  6. rebelrat
    rebelrat
    is it done yet ?
  7. scoobyscooter
    scoobyscooter
    Thats insane....i dig it
  8. BatzNY
    BatzNY
    words can not describe the envy and awe of this i possess !!!
    Batz
  9. HealeyRick
    HealeyRick
    from Mass.
    I gotta think making this into a motorhome is way easier than making a motorhome into a flying machine. Good luck, very cool!
  10. stainlesssteelrat
    stainlesssteelrat
    from ms
  11. Metaltwister
    Metaltwister
    Is it done yet? Now that is a project:eek: Patiently watching...
  12. mashed
    mashed
    from 4077th
  13. flt-blk
    flt-blk
    from IL
    Are these things all over, I saw this one around Sioux Falls over 4th of July
    Not sure if it is the same type of plane or not.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  14. I love those airplanes... I worked on its "Big Brother" the PV-2D Har**** sub hunter!
  15. SLAMIT
    SLAMIT
  16. carlisle1926
    carlisle1926
    That Lodestar went to Montana to be used as a guest house. It sat at an airport in Texarkana for a long time. Gary Hilton is the guy that took it apart and drove it all the way up there. I wish that I had that one because my life would be a lot easier not having to repair all of the damage to mine.
  17. Degenerate
    Degenerate
    from Indiana
    Brings back memories. When I was a youngster there used to be a Lodestar owned by Russell-Stover Candies based at the Kansas City Fairfax airport in the mid '60's. It was a very s**** executive conversion. Just watching them pull it out and crank it up would give you goose bumps. What a machine. Right next door at the same airport they built B25's.
  18. Showtime
    Showtime
    so freakin cool
  19. This is one of my most prized prints...
  20. godspeedbear
    godspeedbear
    from golden
    All I can say is Dammmnn!
    Use a nose wheel and 'short' wing landing gear for drive line....
    Man You got me thinking and dreamin.........
  21. budd
    budd
    are there still airplane junk yards in the US?
  22. stealthcruiser
    stealthcruiser
    Yep.
    Several in California, ( Aviation Warehouse comes to mind), in Florida, theres one down the road from me in Griffin , Georgia, ( Atlanta Air Salvage).
    Plenty around.
  23. Salty
    Salty
    from Florida
    AZ has a bunch of em too....
    this thread.....too freakin cool! Least my wife now knows there are nuttier folks out there than me
  24. vividlyvintage
    vividlyvintage
    That thing is so crazy, you can,connect a steering shaft to the steering wheel and drive it from that top windshield. That thing is over the top
    Thanks,
    "Skrach"
    My Vintage Blog:
    www.VividlyVintage.com
    My 55 Chrysler Worklog:
    www.Pop's55.com
  25. Hell yes, California Airframe near near the Oakland CA airport.
    That's a Lockheed Hudson, the Military version of the Lodestar. Used for transport, glider towing, reconnaissance and occasional short range bombing missions.The Australians bought a bunch. There's probably a stash of parts over there. Perfect for flying your sheep from station to station.:D
  26. TheMonkey
    TheMonkey
    from MN
    if it's only 7000 pounds, you could do turbo diesel and drag race it.
    maybe consider trailing arms for IRS. could tuck a pumpkin up a bit into belly with 934 cv joints and axles sticking out the skin to your hubs. with the right pivots, could create the camber change you drew into your sketch.
    take a look at the offroad crowd for ideas, they make stuff that sometimes looks like landing gear:
  27. TheMonkey
    TheMonkey
    from MN
    also be kind of cool to figure a way to do a CVT transmission with loud exhaust so it sounds like a plane taking off.
  28. Willy301
    Willy301
    I am just wondering if you could use the Dana 70 as you propose, but tuck it up in the ch***is, and then make CV shaft come off the ends of that and hook to the outboard of your IRS. The brakes could remain on the end of the D-70 and still be very serviceable. It would also allow you to get your width. You could even shorten the 70 a bit to get the CV shafts longer for the better articulation.
