1951 216 Chevy starter
Discussion in 'The Hokey Ass Message Board' started by ttypeturbo, Jan 25, 2012.
  1. ttypeturbo
    ttypeturbo
    Hi gang,
    I had a 1951 Chevy Deluxe all original 4 door given to me the other day. It seems to have been sitting since the early 80’s and I have been trying to start it so I can figure weather I want to keep it intact or part it since I have a 51 coupe. I tried to start it with a remote switch to the starter but it was a no go. I removed the starter and was able to get the solenoid going but the starter seems to be dead. I don’t want to spend much trying to start it so I’ve been searching for a cheap starter and came across one for 43 bucks at Advance Auto Parts, a Beck/Arnley part number 187-6167. They list this same starter to fit the 216/235 from 49 to 61 but from what I understand from searching the forum is that all 12 volt post 55 cars had a different starter/flywheel combo. O’reillys list this same starter for the same year ranges as well. Any thoughts on if this will work at all? Any thoughts or suggestions appreciated.
    Thanks!
  2. 50ChevyFrank
    50ChevyFrank
    I don't understand the same starter being listed for 49-61... unless the drive gear/pinion on the starter is some compromise that will mesh with either ring gear...?? guessing.
  3. ttypeturbo
    ttypeturbo
    This one has me scratching my head. Maybe I should go the safe route and look for a starter rebuild kit? I would hate to give up my core if the Advance starter won't work but that's onlt 10 bucks and the Advance starter could be returned I guess. I was hoping there was someone that has tried this starter.
  4. squirrel
  5. ttypeturbo
    ttypeturbo
    Excellent link, thank you! I'm thinking about pulling it apart now.
